Fuel tank question
  • Vdubmt
    • Feb 2013
    • 50
    Fuel tank question
    I have an early model with a pump in the tank and the main under the car. From my understanding there is a fuel line that connects the left side of the tank to the right side. I believe that this line is clogged. Can it be replaced? If so, is it a pain to replace or remove to try and clean?
    (OO=[][]=OO)
  • TSI
    • Mar 2012
    • 691
    Can it be replaced? Yes.
    Is it a pain? Massively so. You have to remove exhaust, driveshaft, undo the tank and drop it. Definitely not fun. Took me 3 days b/c of rusty bolts last time.
    • TobyB
      • 5238
      tank- yes, pain.
      Tube- no, easy. Remove rear heat shield, there it is.
      t
      • peytonracer4
        • May 2011
        • 524
        assuming it's not rust welded then it's fairly straight forward. it sits at the bottom of the tanks and is easily visible.
        however most are probably completely one with the tank at this point.
        • Vdubmt
          • Feb 2013
          • 50
          I'm going to assume that it will be rusted on. When I picked the car up I had to replace the in tank pump, filter, external pump and rebuild the injectors because of rust settlement. So at this point it may be just as easy as swapping the complete tank out from what it sounds. I was trying to avoid that because the exhaust looks like it's going to be a pain to drop. Thanks for the replies.
          (OO=[][]=OO)
