burnt ECU
  • CLASH
    • Nov 2013
    • 39
    burnt ECU
    hi everyone. Just like the title says my ECU got some damage to it, according to my ICV kept on running while the key off. I took out the ECU #173 and open it I saw this ECU was some how rebuild in 2006 and the looked at the job that they did was horrible as far my electronic skill I can say it look really bad. One of the component there they are joint up many legs on, I tried to separate them but no point the printed nine was already cut.
    so here my problem I still can drive the car with this ECU and the battery always drain.
    if I want to buy another ECU let say the MS DIY kit and build it myself. What else do I need to make the MS runs with my stock engine?
    do I need to install wideband O2?
    will all the gauges on cluster works?
    if nearly future I decide to install a turbo what parts do I need to make it works?.
    my budget is small.
    sorry for my English.
    thanks
  • Wanganstyle
    • 2828
    Just get a replacement 173. Inexpensive
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
      • 34844
      a used 173 is like $35..
      • CLASH
        • Nov 2013
        • 39
        Can't find any of them local.
        Is there any place recommended to look for?
        Thanks
        • squidmaster
          • Aug 2011
          • 2666
          Junk yard! You can probably pick up a few and make some bucks back.
            • 34844
            Thanks
            the FS forum?
