Speedo/ODO help
  • KDAWG97M3
    • Sep 2009
    • 347
    Speedo/ODO help
    Ok, so I have swapped clusters, changed odo gears, correctly, and have even taken aprt to do it again...so here is my issue
    My speedo will work sometimes, not all the time, when it works, it will work for a bit, then spike the stop...my Mpgs wasn't working, now is...my coolant guage works..gas is quirky?? Now the kicker the odo doesn't work (gears replaced).it won't collect mileage??
    I have check the diff sensor..the prongs looks brand new, the connector as well?? This is m20 325ix?? Any help would be great...thanks
  • KDAWG97M3
    • Sep 2009
    • 347
    Guys?? No ideas here??
    • accident
      • 7303
      Are the service indicator lights working properly? Sounds like your SI board took a shit.
      Moral of this story?
      • KDAWG97M3
        • Sep 2009
        • 347
        Failed to mention. They work just fine.
        • Gregs///M
          • Mar 2012
          • 2459
          Replace fuse 10, 12, and 21 first. If your speedo and odo fail at the same time, the problem is most likely fuses or speed sensor connection.
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
            • 34844
            SI board doesn't have anything to do with the speedometer
            do you have a 13 button OBC?
