turbo in an Eta?
  • JPbmw
    • 466
    turbo in an Eta?
    has any one done a turbo set up with a Eta engine?
    also is there a reason why you should not to run a turbo in a stock eta(maybe with the MAF conversion)
    Thanks
    '86 325
  • redbull 325is
    • 7471
    one problem : single valve springs.
    Julien
    Build Threads:
      • 34844
      the low redline and restrictive head/intake don't help much either.
      • redbull 325is
        • 7471
        Re: turbo in an Eta?
        Thanks
        a euro 323i top end might do it for you... but its cheaper to pic up a used m20b25.
        Julien
        Build Threads:
        • JPbmw
          • 466
          Ok i guess im gonna start searching for a m20b25 then :twisted: , what is needed for the m20b25 conversion except for the engine, whiring harness, intake manifold, exhaust manifold, is the computer(ECU also needed?)
          '86 325
          • Fred
            • 659
            Yes. You need the long block, computer, and everything that the wiring harness plugs into (O2 sensor, TPS, AFM, ICV, crank sensor, electronic purge valve, fuel injectors, etc etc).
            '86 325 2.8i stroker - Arctic Blue
            '11 328i Sports Wagon - LeMans Blue
            Strictly Eta
            • RedBaron86325
              • 386
              Why not turbo an eta? Add the double valve springs and you should be fine. Select the correct size turbo to accomodate the cam and the amount of revs. If you can turbo a Briggs&Stratton lawnmower engine, you can surely turbo an eta.
              Odd that you don't hear m42'ers criticize m10 turbos.
              Don't forget the good things Hitler did.
              • JPbmw
                • 466
                what would be easier/cheaper to do; the E to I swap or the full m20b25 engine conversion (btw this is my daily driver and i plan on doing the turbo set up also)
                Thanks
                Edit: "O2 sensor, TPS, AFM, ICV, crank sensor, electronic purge valve, fuel injectors" most of this stuff already comes with the engine so there shouldnt be much modifications need
                '86 325
                • Rob
                  • 8166
                  thats because m10s made a lot of power in old race motors, ETAs didnt AFAIK...
                  BEERTECH
                  • Jarvis
                    • 2132
                    AND it costs about $200 to replace the whole M10 engine in case you blow it up turboing the shit out of it.
                    • darien28
                      • Jan 2004
                      • 240
                      rofl... onthe m10 $200 thing
                      you'll basically want to swap in a super-eta motor since that's a good stock starting point for turbo if you're on the cheap... it's got the i head and 2.7 crank already. you just want to lower the compression a bit and you'll be good to go for low low boost...
                      I'm building a FI 2.8l... details once I get all my parts and the piping planned out.
                      • Jarvis
                        • 2132
                        Don't Super Eta's already have a 8.5:1 compression ratio? That'd be perfect for lower boost situations. Even the 8.8:1 in stock 'i' engines is a pretty good starting point for low boost. The 9.0:1 'e' engines are pushing it though.
                        • OreoGaborio
                          • 1285
                          make a 2.7i engine & keep the 325i pistons... it'll be pretty low compression, then you can turbo the fuck out of it :twisted:
                          -Pete, who sometimes says things that make sense even though he hasn't researched it 8) (ie, look into that a little more before you try to do it)
                          -Pete
                          LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
                          Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
                          The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
                          • BMW BMXER
                            • 2325
                            A member on maxbimmer did it.
                            Sold it.
                            • kansas-ix
                              • Jan 2004
                              • 1600
                              you can definitely turbo an eta look:
                              there it is talk to him I bet he can answer your questions.
                              E30 325ix 62k
