radiator with built in overflow??
  • dustyperez
    • Feb 2012
    • 390
    I been searching for hours now and I thought this was somewhere but idk.
    I am looking for and all aluminum rad with the overflow tank on it, so you can clean up the bay some. I thought there was a group buy or something. Also what hoses would you need then? I did see one on ebay but it was like 800 bucks
  • oliver.r
    • Mar 2012
    • 3839
    aluminum rads with built in reservoirs are a lot of money, youre not going to find something reputable for under that
      • 34844
      a new overflow tank is only $100. I think you could probably buy 2-3 aluminum radiators with what you'd have leftover.
      • jalopi
        • 2370
        If you're that hell bent on having an integral overflow tank, I'd just buy a mishimoto radiator, drop it in, take some measurements, take it to a rad shop and have them make the overflow tank to your specifications.
        The rad can be had for $250 or so, all you need to do is see how much a shop would charge. In the end though.... you probably wouldn't even save that much money.... maybe even spend more. Call around.
        • dustyperez
          • Feb 2012
          • 390
          I thought the e36 had a built in tank? Im sure I saw a retrofit somewhere. Like for guys doin a wire tuck and shaved bay.
          Sent from my SCH-I545 using Tapatalk
          • oliver.r
            • Mar 2012
            • 3839
            oh I thought you were looking for a "aluminum: as in aftermarket rad
            • oliver.r
              • Mar 2012
              • 3839
              m42 rads and e36/e46 rads have attached res
              • dustyperez
                • Feb 2012
                • 390
                Yes I was. I have a regular all alum now. I just thought there was one with a tank floating around
                • Wanganstyle
                  • 2828
                  the original e30 overflow tank position (early or late) is better honestly.
                  E36M guys who are serious often fit the european overflow tank (its a e30 overflow tank mounted to the firewall).
                  This would be me x2 e36M's
                    • 34844
                    the E36 rad has it mounted right next to it, but it's not integrated. E30 and E36s radiators are the same.
                    the M42 has it built in, but it's a bit on the small size.
                    • oliver.r
                      • Mar 2012
                      • 3839
                      isn't it easier to bleed with a higher overflow tank or something along those lines
                      • Wanganstyle
                        • 2828
                        those lines
                        Air travels UP when its in water....................
                        the e36's bleed much better when the euro bottle (late model e30 bottle) is fitted.
                        the USA model e36 is known for stupid bleeder plastic screw issues. overflow tank mounting is also crap (1 plastic clip) compared to a e30 or E36 euro mounting with steel brackets.
                          • 34844
                          never had a problem with the late E30 tank.
                          one thing I don't like about the early one is it's right over the headers.
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Zionsville sells an all aluminum M42 radiator with the tank built in:
                            • dustyperez
                              • Feb 2012
                              • 390
                              thats what i saw on ebay, i just thought i saw a cheap one on here from Mishi, i guess not
