Brake pedal feel question
  • Bglad
    • Jul 2010
    • 562
    So I just got done rebuilding all four calipers, new pads (Hawk HP+), rotors on all four corners and installed SS lines. Bled the system with RPF600 300ml rears, and 200ml fronts to ensure I had a good flush.
    Now my issue is that when I push the brakes while driving the pedal is a little soft/delayed, then another quick tap on it and its good and firm. I can pump the pedal in the car with it off and it builds pressure and remains and I've checked for leaks at all places with none to be found. I was going to bleed the system again in the next couple days and see if that fixes it. Other than that the brakes work amazing.
    Just seeing if anyone else has had a similar issue and what it was?
    Car is a 91 318is BTW.
  • matthugie
    • Mar 2004
    • 1810
    Sounds like it needs to be bled again, or you might have a caliper that didn't seal properly and has a small leak.
    88 325is - S52 powered
    Originally posted by King Arthur
    We'll not risk another frontal assault, that rabbit's dynamite!
    • Bglad
      • Jul 2010
      • 562
      Thats what I was thinking too. I'm doubtful its a bad seal in the caliper, but anything is possible. I bled the system by myself during the half time show. Well see what happens.
      • Todd Black 88
        • Oct 2007
        • 3449
        Did you replace the guide bushings in the calipers, when you rebuilt them?
        That was my issue
        Originally posted by codyep3
        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
        2001 silver/Blk 325 cabby. SOLD
        2002 325xit Sil/blk. SOLD
        2010 F650gs twin
        • Bglad
          • Jul 2010
          • 562
          That was my issue
          Yes I did. I used ATE rebuild kits. I'll take a look at it tonight to make sure nothing is hanging up as I lubed everything well.
            • 34844
            sometimes when I bleed the brakes, I tap the calipers with a ball peen hammer while I've got the bleed screw open. seems to pop some of the stuck air bubbles free. I use a pressure bleeder too, but you can still get bubbles stuck in places.
            • TobyB
              • 5279
              +1 for the tapping. The other thing to do is to go out and stand on them hard a few times.
              The rubber seals are what retract the pistons just a thou or 2 when you release
              pressure, and after a re- sealing, often they over- retract. So the pressure and heat
              of a number of good, hard stops usually helps with that. AND it helps with bleeding.
              What I've found.
              t
              • jalopi
                • 2370
                Tis probably some air in the system, somewhere. Are you bleeding it alone? Try having someone 'stand' on the brakes (apply as much force as humanly possible) while you look for leaks if the sponginess doesn't go away from bleeding.
