Found a bunch of threads had this question asked or touched upon through searching r3v as well as google which lead me to several s14 and e30tech threads but none with a solid conclusion. Has anyone had any luck with this and if so know what bulb is needed to pull this off?
From what I found, the maplights use the light emitted through the side of the bulb which makes the LED solution tricky since they're more or less directional
