QUICK question.....19lbs install
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    so i'm going to install my injectors today, and i read that you should swap FPR with a 2.5bar to ease it in. Do i really need to do that or can i juse use the stock 3.0bar? thanks
  • 88325isboy
    • Mar 2004
    • 1058
    Go to the FAQ section they have a write up in there.
    '87 325 (Track Rat)
    '04 C5500 Wrecker (Work)
    '94 525i (Daily)
    '90 325i (R.I.P)
    H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      thanks i used search but could not find
      • tonytony
        Knee deep in poopie
        • Jan 2004
        • 3498
        bump, still looking for that answer. I've looked
        • MrK
          • Jan 2006
          • 709
          You can just use the stock 3.0 bar, but it'll be a little richer that it should be, and your oxygen sensor will have a hellava time trying to adjust in closed-loop mode. But the car will run.
          BUT.... why not just find a 2.5 bar from a junkyard and use that for a bit? It won't cost you much...
          This is your M20 on steroids:
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            well when i initially posted the topic i was going to do it, now that i've done it i think i will do that. tahnks. the car ran great at first but then it started to stutter, then cleaned up right after that. i did noticed some power, i fish tailed in second and i've never been able to do that before. thanks
              • 34847
              not neccesary. driving the hell out of it is all that's really needed.
              • ZiMMie
                • Jun 2004
                • 968
                wat cars did 2.5bar FPR came in?
                www.stancefactory.com
                • arsevader
                  • May 2005
                  • 1025
                  ETA's
                  • CGDoig
                    • Nov 2005
                    • 348
                    I just swapped, injectors only. Its not worth it unless you're doing the AFM swap or buying a mark d chip made for these injectors. I just did it because i didn't feel like swapping them the same day i get the chip. No power difference, maybe even a loss because of the amount of fuel going through the car. And its definatly running rich.
                    '05 Jetta TDI
                    '87 325iS: Facelift, Hella Smoked Ellipsoids (RIP)
                    '80 320i: 500lbs lighter, Rally/Drifter (SOLD!:( )
                    '90 Jetta: Stock Daily Driver (SOLD)
                    • RobertK
                      Kicked cancer's ASS.
                      • Jun 2005
                      • 5864
                      I was unaware that you're supposed to goto a 2.5 bar FPR if you upgrade to the 19lb injectors. It would also explain why I run very rich when I hit the upper RPMs.
                      So switching from my stock 3.0 bar to a 2.5 bar FPR will fix some of running rich problems?
                      • CGDoig
                        • Nov 2005
                        • 348
                        just inevest in a Mark D chip.
                        '05 Jetta TDI
