Originally posted by vt.bimmer
Killing the annoying door ding...
And mine doesn't even do a good job at that. In every other car I've been in, it'll alert you when the door is closed but not fully closed. In my E30, the door has to be open about 5 inches before the lights turn on or the sound gongs, and if the door is open that wide, it's pretty obvious to EVERYBODY. What's the point of the gong?Originally posted by erik325inope. It gongs if the keys are in and the door is open, but will NOT warn you if you forget the lights on.Comment
To be annoying.Originally posted by DaveInLAAnd mine doesn't even do a good job at that. In every other car I've been in, it'll alert you when the door is closed but not fully closed. In my E30, the door has to be open about 5 inches before the lights turn on or the sound gongs, and if the door is open that wide, it's pretty obvious to EVERYBODY. What's the point of the gong?
It would be cool if you could download a song that played when your door is open kinda like a cell phone.:rofl:
Then what's the point of making the car so that the headlights turn off when you take out the key? I think the sole purpose of that was so that the battery didn't drain out.Originally posted by EurospeedYour headlights turn off, but your front and rear parking lights stay on, and they will drain your battery if left all day/night.Comment
Originally posted by DaveCNThat is the gong and you'll have to remove the bolster.
Not true, you do not have to remove the knee bar. Look under the dash, start at the pedals and follow your way back towards the steering wheel. There are three 8mm hex cap screws holding the lower kick panel to the knee bar, remove those four bolts and there is your "door gong"... No need to remove the bolster (knee bar) to get to it.Signature removed by R3VLimited staff due to a violation of the signature rulesComment
You have a late-model with an airbag knee bolster, it's completely different than the non-airbag bolster. So the way Dave told him to do it IS true. Knowledge is power!Originally posted by Alpine-E30Not true, you do not have to remove the knee bar. Look under the dash, start at the pedals and follow your way back towards the steering wheel. There are three 8mm hex cap screws holding the lower kick panel to the knee bar, remove those four bolts and there is your "door gong"... No need to remove the bolster (knee bar) to get to it.Comment
Every car I have seen, the switch is in the same place. Ranging from cars with airbags to cars without.Originally posted by EurospeedYou have a late-model with an airbag knee bolster, it's completely different than the non-airbag bolster. So the way Dave told him to do it IS true. Knowledge is power!Signature removed by R3VLimited staff due to a violation of the signature rulesComment
