VDO Fuel Level Gauge Retrofit
  • ivprodigy
    • Feb 2014
    • 33
    I have been making good progress on my track E30.
    The previous owner was pretty keen on weight saving so most everything from the interior went the way of the dodo.
    The car now has VDO gauges and MS instead of the stock gauge (not sure why that was necessary but it is what I am working with).
    From my research the fuel level senders in the tank have a range of 0-60ohms.
    The VDO gauge that came with the car operates on a 0-90ohm range and it doesn't seem to work (no surprise there).
    Has anyone gone away from using the stock gauges?
    Does anyone have suggestions on how I can remedy my dilemma?
    working progress...
    I've been told that Stack makes a fuel gauge that can be programmed for the resistance range of the stock VDO sensor. Not only is the range odd, but it works backwards (zero ohms full).
    • ivprodigy
      • Feb 2014
      • 33
      Thanks Jim!
      I hadn't thought about programmable gauges.
      The Stack gauges are nice but they are also $$$ and it'd be hard to justify it for a track car that won't see too much street driving.
      For now, it looks like I'll just have to note where on the gauge I get full (it looks to be somewhere past the half mark) and empty (buried past the full mark)...
      It's ghetto, yes, but it'll do the trick for the time being...
      PS I picked the car up from a SCCA guy down by Birmingham almost a year ago. I am very jealous of the nice weather and longer track season you AL guys get. It snowed again in Chicago the other day...
      working progress...
      • AndrewBird
        The Mad Scientist
        • 11898
        You could add a resistor inline with the gauge and shift the scale over so it would be a bit more useful. It would be a guess and check kind of thing on what resistor you would need. Start with a 20 ohm or so and see what that does, then just adjust from there.
        • ivprodigy
          • Feb 2014
          • 33
          Great!
          I hadn't thought of that.
          I have to see if I have any spare resistors in my random parts bin or check radio shack.
          Thanks
          working progress...
            I have an easier fix. Connect a light to the low fuel switch in the sensor. It will come on when there is 2-3 gallons left in the tank. On track, start with a full tank and refill at noon. When driving to/from the track, carry an extra 2-3 gallons in portable tanks(). If the light comes on and you aren't near a gas station, add the fuel from the portable tanks and refill at the next gas station.
            • Digitalwave
              is a poseur
              • 6299
              Did you ever get this working ivprodigy?
              RISING EDGE
              • ivprodigy
                • Feb 2014
                • 33
                Well not in the way I had hoped.
                I couldn't get the VDO gauge to read in any measurable way.
                I ended up picking up the AutoMeter Programmable Fuel Level Gauge 3310 which allows you to set the E/F range manually (their pre set ranges don't match the e30)
                https://www.autometer.com/2-1-16-fue...port-comp.html
                I've not yet installed it. The engine is out and getting rebuilt but once it warms up I'll be putting it.
                working progress...
                • Digitalwave
                  is a poseur
                  • 6299
                  Thanks! I think that one or the STACK programmable version would work well. I'm hoping to ditch my cluster completely.
                  RISING EDGE
                  • Jean
                    • 18228
                    VDO also makes aftermarket floats/senders for their fuel level gauges as another option.
                    • TobyB
                      • 5280
                      Doesn't the BMW way run backwards to the usual-
                      as in, 90 ohms is FULL, 10 empty, if the usual way is
                      to have empty be 60, 0 full? (or reverse that, I forget)
                      It makes it a real pain to convert, as it's both upside down AND the wrong range..
                      t
                      • vpilarrt
                        • Jun 2006
                        • 2096
                        Remember there are 2 sensors wired in series on the M20 engine E30. On my track car I disconnected and the shorted the wires to each other at the driver side sensor and am only using the passenger side sensor to drive my VDO gauge. It's not perfect but works well enough to remind me if I've filled the tank.
                        Typical scenario for a track day - fill up the car and two 5 gallon cans on the way to the track. About 1/2 way through the 3rd session I start to get starvation on long right hand turns. Flip on 2nd fuel pump in driver side tank (a low pressure pump that transfers fuel to the passenger side). Dump a 5 gallon can in at end of session. Dump the other 5 gallon can at end of 4th session if I get more track time (see Open Track events at Trackdaze). Go home with ~1/3 tank of fuel. Repeat.
                        • Digitalwave
                          is a poseur
                          • 6299
                          My car only has one level sender, but I do know that the sensor works in reverse (0 when full). I don't know if that would trip up those programmable gauges or not.
                          RISING EDGE
                          • vpilarrt
                            • Jun 2006
                            • 2096
                            VDO sells both 0-90 and 90-0 fuel level gauges
                            • TobyB
                              • 5280
                              Plastic bumpered cars have 2, aluminum have one, approximately.
                              If you have a pipe between the 2 sides of the tank, under the driveshaft,
                              there's only one sender.
                              The gauge changes, the value of the sensor does not, as in,
                              the 2 senders are wired in series. So a 2 sender car reads 120- 0, and the 1 sender
                              car reads 60- 0.
                              Makes dash- swapping interesting, among other things.
                              t
