Battery keeps getting drained
  • Stevoyayaya3
    • Aug 2013
    • 315
    So my battery won't hold a charge on my m42. About a week ago I changed the oil filter housing gasket and out everything back the tension on the alternator feels the same maybe just a tad more slack. Any idea what could cause it or the first thing to check? If I get my car jumped it will drive fine until I cut it off. Thanks in advance guys
  • jalopi
    • 2370
    How old is the battery? Some of the cheaper ones are only good for a few years. Anyway...
    Check the static battery voltage.
    If it's above/around, say, 12V: check the cranking voltage of the battery. If it drops below 9-10V during cranking your battery is shit, you're gonna have to replace it.
    If it's below, say, 12V: you need to do a draw test to see what's killing your battery.
    I'd do a draw test even if you replace the battery, just to be sure.
    • Stevoyayaya3
      • Aug 2013
      • 315
      Ya I did take the battery to autozone and they said the battery was bad. I had put a smaller battery from my 92 civic in and it killed that in a couple of days. Exactly how would I do a draw test? Thank you
      • jalopi
        • 2370
        Read this:
        You need a multimeter. Make sure you don't hook it up in parallel or you'll kill the meters' fuse. Don't work the windows, radio, any controls, ect or you can kill the meters' fuse.
        • Stevoyayaya3
          • Aug 2013
          • 315
          Just updating for maybe someone who has had this problem. My mechanic had my car for almost 6 months and couldn't figure it out, but I did a little research and changed out the voltage regulator and the problem was solved. Just make sure to get the correct regulator
          • Stevoyayaya3
            • Aug 2013
            • 315
            And now it's doing the battery drain again. Wtf lol it's been running great for about 5 months lol
            • long tall eta
              • Jul 2010
              • 1536
              check the batteries in your cluster. if bad, you can suck your battery dry.
              • Stevoyayaya3
                • Aug 2013
                • 315
                Like on th si board? I bought a refurbished one from bma about a year ago
                • e30onBBSs
                  • Dec 2014
                  • 1347
                  Check the connections of your cluster, I read somewhere that if not connected the battery won't charge the car for some reason. Also do you have an aftermarket alarm? I've also read/ heard those can be a battery sucker if installed incorrectly or left on or something
                  BMW tech
                  Umass Amherst
                  05 wrx sti
                  • Stevoyayaya3
                    • Aug 2013
                    • 315
                    It was the alternator even though the alternator tested fine lol
                    • TobyB
                      • 5243
                      Wow- and you lived with it for that long???
                      hee
                      t
                      • estoguy
                        • May 2013
                        • 1087
                        Was the entire alternator dead or just the voltage regulator? I had a similar condition a couple years ago, and it was regulator. Easy fix.
                        Estoguy
                        • Gregs///M
                          • Mar 2012
                          • 2459
                          Dont trust those BMA SI boards. IN fact don't trust any SI boards from them, E30_dad or Programa. We repair their SI boards almost weekly.
                          They only change the batteries and capacitors. There are about 15 transistors and voltage regulators which are responsible for the parasitic drain. If the batteries are new, the transistors are still 30 years old and will intermittently and rapidly switch on and off, even with the car off. This is what causes the parasitic drain.
                          If your drain is coming from the either fuse 10, 12 or 21, there is a good chance its the SI board still, super common.
                          Owner - Bavarian Restoration
                          BMW and European Electronics Repair and Restoration
                          www.BavRest.com
                          My Feedback Thread
                          Our Facebook!
                          Follow our Instagram!
