Power Steering Belt Replacement ISSUE
  • Danny51
    • Apr 2014
    • 77
    Hi, I had another thread open on some drive belt questions but have a problem I have narrowed it to.
    I am trying to change the power steering belt and thhe pump/pulley/tensioner will NOT move, Ive loosened all the bolts I can except one which has been stripped. The tooth pin tensioner thingy did absolutely nothing for me and Im getting really frustrated as I've been at this all day. I've tried everything, even just beating at it with a goddamn wrench.
    ANY SOLUTION?
    Thanks
  • vpilarrt
    • Jun 2006
    • 2096
    You have to loosen 5, 7 and 10: http://bmwfans.info/parts-catalog/E3...pump_mounting/.
    If you did and it still won't move you may have to remove the whole thing and brackets to free it up.
    • Danny51
      • Apr 2014
      • 77
      I dont see a 10 in that diagram, But Im assuming its the one right side of the #2. I tried undoing that bolt but its pretty tight in and a little stripped, cant budge it
      • vpilarrt
        • Jun 2006
        • 2096
        No, 10 is on top of 9. For some reason lately the double digit numbers do not show on the bmwfans page. If you select (left click) the number in the diagram and then scoll down you will see that number highlighted next to the part name.
        • elbrack
          • Jul 2013
          • 176
          How the hell do you get to bolt 5 without having it jacked up?
          • Cletonius
            • 2809
            it's all accessible with the car on the ground; you might have to lay under there to get at it.
            I got mine as loose as I could and then used a 2 foot bar and some penetrating oil to free things up.
            - Josh
            1990 325is
            Need a shift boot?
            Looking to buy shift boot frames, PM if you have one to sell
            Here's what happens when you let the internet pick your license plate
