broken brakelights
  • Jordan325iC
    • Aug 2005
    • 1697
    broken brakelights
    Both brakelights are no working. Changed fuses 6,22 and 23, changed the brakelight switch, bulbs are good, wiring looks good.
    I've heard there's some box that controls the brakelights, but I don't know where to find it in the cabrio. Any help?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • chuckybob
    • Aug 2004
    • 952
    donno about the box, but it could be a splice or a ground
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
    • Jordan325iC
      • Aug 2005
      • 1697
      I have no clue about electrical stuff. What can I check, I have no idea what a splice or a ground is.
      '88 325is
      BMWCCA 380364
      • DaN
        • 1265
        Probably a bit out of your element here, any buddies familiar with electronics?
        • chuckybob
          • Aug 2004
          • 952
          a splice is where two wires are connected into one, a ground is where an electrical circut makes contact with the chasis to complete the circut. if the splice is broken, or the ground is dirty and/or rusted through, electricity wont be able to go through, and stuff stops working. as for which grounds and splices, i have no idea. i think maybe splice 201?
          • Jordan325iC
            • Aug 2005
            • 1697
            I've found 2 loose connections with enough play that they could have possibly connected to something else, but I'm not sure.
            A black connector with 2 flat connectors with a brown/black wire going to it, says +12V on it.
            A long orange connector with 6 round connections on it, with a white/black, a green/black, a red, a purple and a brown wire going to it.
            I don't see anywhere obvious for those to connect to. Any of that help?
            '88 325is
            BMWCCA 380364
