With early cars (325e, M3, etc) that have the low pressure in-tank pump, this pump is supplying less than 8psi to the main (in-line) pump.
On later single-pump cars such as the 318iS, this in-tank pump is supplying much higher pressures. I have repaired such higher pressure pumps by replacing the dead motor with a Walbro 255lph unit or similar.
What would be the result if the low-pressure pump was replaced with a 150-250lph pump? What would be the effect on the main (in-line) pump?
