A "while I'm in there" topic.
  • Haystack
    • Mar 2014
    • 213
    87 325- I'm replacing my subframe, motor mounts (with condor) and oil pan.
    Besides a steering rack, what else should I replace while I've got everything apart?
  • lambo
    Captain Scene Points
    • 10953
    Check all of your bushings, brakes and brake lines
    • jalopi
      • 2370
      If by steering rack you mean an e36 rack, then yes. If not, you should make that a yes ;)
      Replace the trans mount when you do the engine mounts, your radiator will thank you
      • kung fu jesus
        • 163
        PS line, steering giubo.
        '88 325is
        Alpinweiss
        • TobyB
          • 5297
          And the snubby thing that hits the subframe just to make sure your waterpump doesn't
          make sweet love to your radiator, too...
          t
