Electrical woes...need help. Half the cluster lights + euro clock light doesn't work
  • audiquattrot
    • May 2008
    • 3836
    Just to rewind for a sec, I was driving to work this morning....and noticed my 'check' light go on. I looked on the check panel, and it said my license plate lights & taillights were out. This all led back to fuse #23, which is a 7.5A fuse. For some reason it kept blowing out every time i went to put a new one in.
    I then started to diagnose where the short could be so I started w/ the license plate lights. Took both out, and seem somewhat corroded. I tried putting a new fuse in w/ the lights out, and still burnt the fuse.
    Gave it one more shot by putting yet another 7.5A fuse in #23, and got my taillights and license plates to work....BUT now half my cluster doesn't light up + the euro clock light doesn't illuminate either! I swapped the euro clock bulb w/ 3 different 'good' bulbs...and still nothing.
    Question is did i fry something? Or is there another known problem I can check?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • Gregs///M
    • Mar 2012
    • 2459
    Check fuse 10, 12, and 21, those are associated with clock, OBC, and cluster. Then do not install higher value fuses in place of smaller values. Inspect shifter area, under rear seat, and trunk wiring harness for burning, charring, or insulation damage.
    Sent from my Nexus 7 using Tapatalk
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • audiquattrot
      • May 2008
      • 3836
      Thanks for the quick reply! I checked every fuse in the fuse box and they are all good. I will check those wires u mentioned tomorrow for sure. I guess my next question is, did I happen to damage something within the cluster itself where it doesn't illuminate on half if it + the euro clock? #23 fuse doesn't blow out anymore w the 7.5A, and I'm wondering that if I had you repair my cluster if my gremlins will return again once that's fully functioning.
      I'm still puzzled as to where the root of the problem could be coming from....or if the problem stemmed from the cluster all along causing the license plate and right taillight to go out
      #snwmble
      Current:
      Past:
      • audiquattrot
        • May 2008
        • 3836
        Also one last question. How exactly does the obc/euro clock draw power from the cluster to illuminate it? If the right side of the cluster bulb is burnt out, does that mean the obc/euro clock will be out too even though the bulb within the obc/clock is good? I'm kind if hoping the bulb just burnt out in the cluster...,but the fact that swapping out numerous good bulbs in the euro clock leads me to believe somethjng else is f'd
        #snwmble
        Current:
        Past:
        • audiquattrot
          • May 2008
          • 3836
          Any insight is appreciated, thanks!
          #snwmble
          Current:
          Past:
          • audiquattrot
            • May 2008
            • 3836
            can anyone tell me where this instrument light cluster relay is located?
            http://www.ebay.com/itm/BMW-E30-3SER...item3cd1707946
            #snwmble
            Current:
            Past:
            • spdracrm3
              • Sep 2009
              • 959
              left rear of trunk ,above power antenna and behind amplifier
              Angus
              88 E30M3 X2
              89 325IX
              92 R100GS/PD
              • audiquattrot
                • May 2008
                • 3836
                perfect thanks! Do you know exactly what this relay controls? Would my issue above be the cause of this relay going bad you think?
                #snwmble
                Current:
                Past:
                • audiquattrot
                  • May 2008
                  • 3836
                  this was the culprit.
                  #snwmble
                  Current:
                  Past:
