I need help fuel pump
  • zambizzi
    • Mar 2014
    • 41
    do I need 2 fuel pumps for a late model m20b25?
    also can I reuse a m40 fuel pump?
  • dnguyen1963
    • Nov 2011
    • 2649
    What year is your car?
    • vpilarrt
      • Jun 2006
      • 2096
      Looks like M40s before March '88 used a 2 pump system, after Mar '88 they used a single high pressure pump like the late model US M20B25.
      • zambizzi
        • Mar 2014
        • 41
        I have a 1991 318i
        • zambizzi
          • Mar 2014
          • 41
          Originally posted by dnguyen1963
          what year is your car?
          1991
          • uturn
            • Dec 2010
            • 1001
            The fuel pump in your car is different from the one found in cars with the m20b25. I spent $400 to find out.
            • SmokeE30
              • 1730
              It is a different pump, but I know an m20 will run with a stock 91 318is pump setup.
              Shawn @ Bimmerbuddies
              Bimmerbuddies LLC
              717-388-1256
              2971a Roundtop Rd, Middletown PA 17057
              bimmerbuddiesllc@gmail.com
              • dnguyen1963
                • Nov 2011
                • 2649
                Here it is...single high pressure pump.
                TREperformance sells high pressure 255 LPH fuel pumps for all BMW vehicles including the 318i, 318ic, 318is and 318ti. These performance pumps will fit any BMW 318 and flow 255LPH and support 500hp.
                • zambizzi
                  • Mar 2014
                  • 41
                  wow its so inexpensive
                  • zambizzi
                    • Mar 2014
                    • 41
                    ok I hope it works because In Europe we have the m40 which is sohc 4cyl and the is is the m42 dohc idk if that makes a lot of difference with fuel needs
                    • zambizzi
                      • Mar 2014
                      • 41
                      http://treperformance.com/i-6323866-...1990-1999.html
                      have you ordered from them before?
                      • Gary Horneck
                        • May 2011
                        • 435
                        I've been running the TRE pump for 3 yrs. Works well, they are a good company.
                        2011 335i/1995 Mercedes C220 (rallyx)
                          The single in-tank high pressure pump for a late production 318is is not the same as the pump for a 325is/i/ic built from 9/87 on.
