removing cruise control switch
  • ///M42 sport
    • 3952
    is this a pain the ass to do?
  • ZiMMie
    • Jun 2004
    • 968
    the stalk?
    No the stearing wheels comes off. then u open the 4 bolts (2up,2below) for the coloum. u should see the screw that holds the stalk in place.
    www.stancefactory.com
    • parkerbink
      • Jun 2004
      • 10137
      Define pita.
      Remove steering wheel (if airbag car you are supposed to disarm the airbag) which in it's self is a long major pita process.
      Remove knee bolster.
      Remove big hard to reach screws behind dash (x2)
      Remove steering wheel covers (pita)
      Remove two screws holding cc switch, detach connector, un-snake connecter & wires from the rest of the wires. (no fun)
      This is from memory when I replaced mine when the cc was not working, I am sure I am forgetting something.
      Just the airbag process exceeds my pita threshold, I had switched to an Mtech1 wheel when I did this so that was done in my case. The rest by far exceeds pita status imho especially if you are only doing it to remove the switch. I say leave it there.
      • ///M42 sport
        • 3952
        well I just need to remove the stalk from a parts car. Can the wiring be detached from the stalk?
        • parkerbink
          • Jun 2004
          • 10137
          The wiring is soldered into the stalk.
          • Sean
            • 5793
            there's a plug though, no need to remove the wires.
            - Sean Hayes
