Turn Signal Problem
  • Jrssampson
    • Mar 2014
    • 109
    Turn Signal Problem
    My front left turn signal does not work. I have replaced the bulb and fuse, neither helped.
  • FLG
    • Sep 2011
    • 3165
    What does it do?
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • itskingsteelo
      • Jul 2013
      • 1340
      My turn signal has a problem too, when i put it on it clicks way too fast
      Originally posted by dvck
      • FLG
        • Sep 2011
        • 3165
        Most issues are due to dirty connections or bad bulbs.
        Clean all bulb sockets and replace the bulbs
        • itskingsteelo
          • Jul 2013
          • 1340
          sometimes when I click it on, it clicks normally but sometimes its too slow or too fast
          • mitchlikesbikes
            • Dec 2013
            • 858
            your flasher might be bad or have dirty connections. get to that and make sure it's clean too. it's plugged in to the turn signal switch harness inside the steering column cover thing
            IG: @mitchlikesbikes
            • noid
              • 1530
              That means one of your bulbs is out in the direction where it clicks to fast.
              Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
              Your resource to tools and tips: www.rtstools.com
              • Sea Aych
                • Apr 2013
                • 763
                Grounding issue. Had the same problem numerous times. Clean the connection in the light housing itself. If that doesn't work, check the connections on the other end, at the turn signal stalk end.
                1988 Atlantisblau Euro/Japanese 325i Cabriolet
                1989 Schwartz 325i - now M50 powered! - now very dead
                1998 Toyota 4Runner Limited
                My 17,000km Big NA National Parks trip!
                • theKrampus
                  • Jul 2014
                  • 96
                  I'm surprised no one has mentioned the relay?
                  • FLG
                    • Sep 2011
                    • 3165
                    If it's only one side it wouldnt be the relay.
                    • Reignity
                      • Jul 2014
                      • 18
                      I've had this issue once after a rainy night. Just turned out to be a dirty connection since the lights don't seal. Unplugged the lights, checked the pins, plugged it back in, and then it worked.
