Alright, so my central locking isn't working and was hoping I could get some help here. I'll try and lay out the line of events as simply as I can.
1. Central locking working perfectly on a E30 318i sedan. Central locking activates from drivers door or boot.
2. One day, drivers door actuator is stuck. Can't physically lock or unlock. Took apart door panel and removed actuator. After banging it a bit, it starts to seemingly work again. Reinstalled in the door.
3. Soon after, the actuator in the passenger front door is stuck too. Repeat same procedure.
4. At this point, the central locking stops working.
Things I have done:
- Checked fuses
- Cleaned door plug with contact cleaner
- Red/black loop eliminated (this was already done, didn't change this)
- Replaced control module (in the speaker bay)
- Replaced drivers door actuator
Nothing has worked.
Symptoms:
- Central locking doesn't work at all now.
- When I lock or unlock the drivers door, I can hear relays clicking in the control module. But nothing happens.
- Occasionally, I'll hear some whirring from the back (maybe the petrol lock actuator) when I lock/unlock the drivers door.
I'm suspecting wiring or something. The electrical reference guide mentions a test I can do by shorting wires on the control module plug, but I don't quite understand how to do it. Would really appreciate if someone could explain that to me.
Thanks!
Things I have done:
- Checked fuses
Nothing has worked.
Symptoms:
Thanks!
