Do you have a spark plug pulled in your video?
If not you have a compression loss on at least one cylinder.
It's time to recheck your cam belt and do a compression test. If the DME does not see a sync signal (the plug wire with the sensor on it) It will not signal the coil to fire. If your cam timing is off then that won't happen.
How long has it had that skip when cranking?
