Car cranking, but not starting(Now with spark!)
  • iceman
    • Jan 2011
    • 149
    #91
    I don't think anyone told you to clean the idle control valve? I was in the same situation and that was my fix. It is a likely culprit for crank no start.
    Don't give up, you can figure it out.
    Here is my basic checklist, sorry if something is redundant.
    (1) Sensors/ecu stuff critical to starting:
    coolant temp
    crank sensor and its reference markings (you checked that)
    afm
    idle control valve
    (2) Fuel
    Is the pump running while you are cranking the engine? Fuel should be coming out of the regulator or the feed hose while you crank the engine. You could also jump the pump by pulling the relay and using a piece of wire, it is in a group of three in front of the fuse box.
    (3)Air
    Look for large vacuum leaks
    (4) Ground wires, there is one from the engine to chassis, one under the back seat (for the pump I think...), one under the dash, and on the m20b27 under the intake manifold for the ecu, idk where it is for the b25.
    (5)Clean and dry ignition stuff, but you did that.
    • ST1G
      • Oct 2012
      • 6689
      #92
      Originally posted by iceman
      I don't think anyone told you to clean the idle control valve? I was in the same situation and that was my fix. It is good one for hard/no starts with cranking and would explain why it starting correlated to you blipping the throttle.
      But it would not explain no spark. It's not an intricate part of the ignition system from my understanding.
      • iceman
        • Jan 2011
        • 149
        #93
        If you are dead positive you have no spark (I don't know what you are doing to test it besides the multimeter on the coil), the pump shouldn't be running either and I think you said you had no fuel coming out of the regulator? This means the ecu is not getting coolant temp or crank position. I think on an m20 it may need afm signal too.
        No the idle control valve is not part of the spark, but it is the air. If the valve is stuck, the car won't start. It is easy enough to check on an m20.
        • iceman
          • Jan 2011
          • 149
          #94
          Has the car always had a manual transmission?
          • ST1G
            • Oct 2012
            • 6689
            #95
            If you are dead positive you have no spark (I don't know what you are doing to test it), the pump shouldn't be running either. This means the ecu is not getting coolant temp or crank position. I think on an m20 it may need afm signal too.
            I'm testing spark in a garage with no windows at night, I would see even the faintest spark. My Method of producing spark works fine on my other m20 e30 with the same coil, wire, and plug.
            I don't hear the fuel pump running either. Coolant temp and afm are not mentioned in the Bentley as required for ignition.
            Right now my main focus is getting spark. It's step two in an engine firing. Once I get spark I'll move onto fuel.
            • ST1G
              • Oct 2012
              • 6689
              #96
              According to the vin decoder it has.
              • iceman
                • Jan 2011
                • 149
                #97
                The ecu tells the pump to turn on. The ecu also turns the coil on. They should happen at the same time. If the fuel is turning on and the spark is not there, it tells you the ecu has what it needs and your fault is somewhere in the ignition. If the spark and fuel is not there you know the ecu is not getting what it needs.
                The fuel pump running will tell you the crank sensor is working.
                • EyExR
                  • Jan 2011
                  • 959
                  #98
                  I'd go through the list again and double check everything. Make sure all sensor clips are well seated and the C191 connector under your manifold is nice and snug with no loose or fouled wires. And check for continuity at the fusible link.
                  My 325iX DIY Threads:
                  Front Wheel Bearing Replacement
                  325iX Rear Subframe Bushings and MUCH more w/pics!
                  325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                  • solo318
                    • Jun 2012
                    • 183
                    #99
                    Look guys. Ignore everything else until you get spark. The spark is triggered directly from the CPS and is the first thing that comes live when the ecu sees engine rotation. Stop with the random guessing about fuel and air shit. Lets get the spark problem figured out.
                    Most fluke meters have an RPM setting if yours does not than you will need to measure a/c voltage at the cps connector with the connector unplugged. Make sure you have a reasonable amount of voltage. What is the cranking voltage of the car (while the starter is engaged).
                    • solo318
                      • Jun 2012
                      • 183
                      #100
                      The other thing that I meant to ask is if you have an aftermarket alarm or tach in the car.
                      Either of these would tie into the coil trigger wire.
                      • HennaE30
                        • Apr 2014
                        • 1965
                        #101
                        Just yank the pos and throw in a m50 do a budget swap.
                        Originally posted by flyboyx
                        how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                        Originally posted by Northern
                        beer is my new liver cleanse.
                        Henna - '84 Hennarot 325e
                        Lola - '89 Schwarz 325is - being saved
                        Christine - '88 Schwarz 325is - Spec E30 Racecar
                        '01 White F150 Lariat 4x4 Supercrew - Daily
                        Dad's '05 Interlagosblau M3
                        • 2002tiiguy
                          • Jul 2013
                          • 467
                          #102
                          Stupid question, did you check fuses?
                          • 2002tiiguy
                            • Jul 2013
                            • 467
                            #103
                            Also, take a test light and clip it to positive and negative on the coil, see if it blinks when you crank it
                            • ST1G
                              • Oct 2012
                              • 6689
                              #104
                              This time 1000
                              I really appreciate the help from everyone, but it's frustrating when you post before reading, and are tossing out an idea that has already been tested and ruled out.
                              I have a euro clock installed. But the car will run even without a cluster in, IIRC.
                              Again, post 66.
                              • 2002tiiguy
                                • Jul 2013
                                • 467
                                #105
                                My bad, thought I read everything
