R3v Fam, need some help. [FIXED!!]
  • Flipp
    • Jul 2014
    • 95
    #31
    Originally posted by HennaE30
    Do you mean 87 and 30? Did you check for voltage at those pins? Also beware, I had this almost identical problem and replaced the fuel pump and it did not fix the problem. Granted, my issue seemed to move throughout the car, but it's just a fair warning.
    yea sorry! im dyslexic, haha. but for real, it kills me sometimes.
    im going to check the voltage tomorrow afternoon.
    • HennaE30
      • Apr 2014
      • 1965
      #32
      Just an FYI, mine turned out to be a loose CPS ground.
      Originally posted by flyboyx
      how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
      Originally posted by Northern
      beer is my new liver cleanse.
      Henna - '84 Hennarot 325e
      Lola - '89 Schwarz 325is - being saved
      Christine - '88 Schwarz 325is - Spec E30 Racecar
      '01 White F150 Lariat 4x4 Supercrew - Daily
      Dad's '05 Interlagosblau M3
      • Flipp
        • Jul 2014
        • 95
        #33
        roger that, ill check that aswell and make sure its good.
        • Flipp
          • Jul 2014
          • 95
          #34
          Anyone have a good/easy way to test the CPS? The description in the Bently book isn't too clear as it tells you to check a black or yellow wire with a multimeter. Only prob is you can't see the black and yellow wires due to the black outer shielding.
          I've read that if you can see that you have spark/fuel the CPS isn't the prob.
          If anyone has a good simple way to go about testing it, do post it up. Thanks!
          • 4tDX
            • Jul 2014
            • 506
            #35
            If you look closely, the prongs should be numbered somewhere on the plastic connector housing.
            If you can't find them you can pull of the rubber boot and check. Check this link to see how the boots attach.
            The black (#2) will be in the center and then you can just put the MM on one of the outside prongs and one of them should give you continuity (~540 ohms).
            The yellow wire is marked '1'.
            • Flipp
              • Jul 2014
              • 95
              #36
              awesome thanks!!
              • Flipp
                • Jul 2014
                • 95
                #37
                hey guys,
                i would have gotten back sooner but it snowed here pretty good and no one could come out to lend me a hand.
                snow finally let up and i was able to have someone come out and give me a hand. i did a simple test on the CPS. i checked for spark, because in my search across the interwebs i read that if you have spark/fuel then the CPS wasnt a factor.
                so with that,
                i have spark, and i have also jumped the fuel pump relay...pump doesnt prime/make any noise what so ever.
                im going to go ahead and rule that its the fuel pump that shit out.
                • HennaE30
                  • Apr 2014
                  • 1965
                  #38
                  hey guys,
                  so with that,
                  Ireland has the cheapest one. But if you want a Bosch one, but through Pelican
                  • Flipp
                    • Jul 2014
                    • 95
                    #39
                    Fuel pump was sitting at the door when I got home. Installed the new one, boom. SHE LIVES!!!!
                    Thanks to those who helped me out with some trouble shooting. I really appreciate it.
