Lets talk radiators. Behr VS Nissens VS Mishimoto
  • Jb325is
    • 2137
    The e28 radiator didn't cool my m30 very well fwiw, but it probably is a hell of a lot more hot/humid down here
    - '88 m54 coupe
    <3
    • FunfGan
      • Jan 2011
      • 4958
      The Mishimoto I purchased for my Mini blew after less than a month, then after paying for the warranty replacement I had to wait 3 months before I finally called to find out that it was back ordered for another 3 months...
      No refund, apology, discount, nothing at all...
      Go here be happy!
      Ratchet Garage e30 V8 build.
      • Ether-D
        • Sep 2011
        • 2838
        So, what rad did you end up with?
        Originally posted by Andy.B
        I was born on 3/25…
        • Jb325is
          • 2137
          I just did an s54 swap instead.
          It wasn't overheating, the fan was just running a lot. I think the e36 m3 radiator or M-coupe radiator would be a better option, but I know clearance is tight with those
          - '88 m54 coupe
          <3
            • 34847
            stock radiators are fine. for the cost ($120?) they'll last 5x longer than Chinese aluminum radiators (even if they come with a warranty).
            I'd go with the Z3M S54 radiator if you want extra cooling capacity.
            • slammin.e28
              שמע ישראל
              • 12054
              I put these in all my cars....even the e34....yes it fits with OEM parts too.
              • Ether-D
                • Sep 2011
                • 2838
                Kickass. Thanks!
                I was born on 3/25…
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  Z3M S54 rad...
                  what are the dimensions like in comparison to the E28 535 rad?
                  I need as much clearance as possible
                  Originally posted by flyboyx
                  i have watched my dog lick himself off a few times
                  • Jb325is
                    • 2137
                    It is considerably thicker, but that's the problem with the e28 radiator. You either get the clearance, or better cooling. I would move the motor back and run the biggest radiator you can. Are you swapping a b34 or b35?
                    - '88 m54 coupe
                    <3
                    • Ether-D
                      • Sep 2011
                      • 2838
                      Here's what I'm working with. It's about 3/8". This is a m20 rad for mocking. I get the feeling I'm pretty far back around position 3. Any idea how much thicker the z3 one is? b34 btdubs on this one. I don't remember what incarnation Mr. Burns was swapping in.
                      I was born on 3/25…
                      • Mr. Burns
                        • Aug 2011
                        • 3516
                        Ether that's decent. Throw on the plugs and you might make it.
                        I'm as far back as I can go insofar as the the engine/firewall will permit.
                        I'll hammer in another inch or so up around/below fan panel for good measure.
                        Jb325is im running a b35
                          • 34847
                          switch to MS3 and run COP. then you don't need that silly cap/rotor any more. :p
                          • Ether-D
                            • Sep 2011
                            • 2838
                            The pulley to radiator clearance is about the same, but yeah. I'll most likely end up doing wasted spark on MS2.
                            I was born on 3/25…
                            • glnr13
                              • 1334
                              in heavy stop and go traffic during the summer and the heat wave a few weeks ago in LA + a pep boys 14" fan i barely crept over the half way mark with the nissens and the behr e28 radiator.
                              did you have ac/condensor?
                              • SkiFree
                                • Jun 2011
                                • 2766
                                No you've got me curious, I recently had aluminum radiators made for the E9 coupe. I'm wondering if it might be a good choice here (dimensions were different/similar to e9/e12/e28 radiators).
                                ADAMS Autosport
