Unleaded or Super?
  • UlrichFennec
    • Dec 2014
    • 1268
    My dad may be a bit daft, but he says I should run higher octane because of the elevation I'm at, and to see if that effects the small engine tick I have going on in the M20. Might need a valve adjustment, but I live in Colorado.
    I just wanna take really great care of my first car.
    "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
    http://www.r3vlimited.com/board/showthread.php?t=366044
    The stickers make it go faster. :nice:
    • dnguyen1963
      • Nov 2011
      • 2649
      Make sure that the tick you hear is not coming from the injectors. Higher octane will not hurt your engine at all...you just might not need it.
      • ST1G
        • Oct 2012
        • 6689
        That just means that you'd be getting less air in the motor. It still shouldn't pre-ignite due to the pressure in the cylinder.
        • indecline
          • Sep 2007
          • 244
          It's best to run quality petrol IE Shell, Chevron, 76. I baby the M20B25 with 91. I like to think it helps for the higher rpm sprints. The Tacoma on the other hand receives 87.
          1989 325I(M20B25US)|KAMotors CAI|Bilstein Sports|H&R Sports|ST Sways|SSSquid Tune|Red46 Sump Armor|
          • dnguyen1963
            • Nov 2011
            • 2649
            Quoted from the internet...
            "Q: I live in Arizona and use 87-octane regular. In Utah, Idaho and Nevada, stations were selling 85-octane as regular gas. This forced me to pay more for midgrade 87-octane. Is this the latest petroleum-industry scam to get more of our money? Will my car run okay on this bogus 85-octane regular?
            A:
            Octane is the ability of a fuel to resist knock, and high-compression engines tend to knock more. The obverse of that is that lower-compression engines can run on lower-octane gas. Air is thinner the higher above sea level you go. Less air going into the cylinders means less pressure at top dead center when things go bang. It's a lot like lowering the compression ratio in the engine, reducing the need for high octane. Cars will run just fine on lower-octane fuel when they're well above sea level--and all of those states are. Hopefully, by the time you get back down to denser air, you've burned off most of the low-octane stuff, and can refill the tank with higher-grade fuel."
            • ST1G
              • Oct 2012
              • 6689
              Originally posted by indecline
              It's best to run quality petrol IE Shell, Chevron, 76. I waste money on the the M20B25 with 91. I like to think it helps for the higher rpm sprints. The Tacoma on the other hand receives 87.
              Fixed that for you.
              • indecline
                • Sep 2007
                • 244
                Originally posted by ST1G
                Fixed that for you.
                I fill up once every two weeks. I doubt you can say the same :p
                • ST1G
                  • Oct 2012
                  • 6689
                  What does filling up every two weeks have to do with irrationally wasting money on premium petrol?
                  You know over the course of 5 years that's over $700 difference at $.30 difference per gallon, 25 mpg, and 12k a year miles. That's not chump change.
                  • dnguyen1963
                    • Nov 2011
                    • 2649
                    What kind of argument is this???
                    • estoguy
                      • May 2013
                      • 1087
                      Bro, it's not the more expensive gas saving you filling up. It's your driving habits. How long is your commute? What kind of MPG are you getting?
                      I've tried the premium vs regular thing in a few different cars - negligible difference in economy - certainly not enough to justify paying the difference.
                      In my Eta, my lifetime average over 2 years has been 7.6L/100 KM (or 31 US/37 UK MPG). At legal speeds, I can easily travel 700 km before I need to think about gas. This is on regular 87. I do run a can of Seafoam between oil changes in the gas. And twice I year I run half a can in the crankcase and intake.
                      Estoguy
                      • indecline
                        • Sep 2007
                        • 244
                        I was simply playing Devil's Advocate, Bruhs!
                        Difference in price from 89-91 is $.16 per gallon. My gas tank has a 16.60 gallon capacity. It's a marginal increase of $2.65 per full tank of gas.
                        The tune I run has a higher ignition timing. Justification.
                        • ST1G
                          • Oct 2012
                          • 6689
                          I don't believe you for a few reasons.
                          1.) If you were playing devils advocate you wouldn't actually put premium fuel in the car.
                          2.) You used the irrational argument that 'you only fill up every two weeks' If you were actually running a tune then that would have been in your original post for your reasoning for running 91, but it wasn't. Your reasoning was that you think 91 is somehow better at higher RPMs.
                          3.) The difference between in price 89 and 91 is irrelevant as long as 91 costs more, since 91 would also be a waste of money in a car tuned for 89. So if you do in fact have a tune for 89, you're still wasting money, and not playing devils advocate.
                          • indecline
                            • Sep 2007
                            • 244
                            I provoked debate for the use of premium fuels. Use what your car is tuned for.
                            • ST1G
                              • Oct 2012
                              • 6689
                              LOL. What ever you need to tell yourself. It's quite obvious you just didn't understand the difference.
                              • indecline
                                • Sep 2007
                                • 244
                                LOL. What ever you need to tell yourself. It's quite obvious I made assumptions and conclusions.
