Clutch in, engine revs? Stumped
  • E30Kills
    • Jul 2014
    • 179
    So recently I let my brake fluid get a bit low. No big deal, just ran to autozone and filled it up again. It wasnt empty, but below the minimum line. Used DOT4 fluid, (as it says on the resevoir) and filled it up. I turned the car on and whenever I put the clutch in the car revs super quickly sometimes to redline. This doesnt happen everytime the clutch is in, maybe half the time. Do i just need to bleed the system? I am stumped
    1991 318i - T-Boned
    1987 325is - Sold
    1991 318is - Current
  • uturn
    • Dec 2010
    • 1008
    Mine did this. The floor mat was binding on the accelerator.
    • ELVA164
      • 4861
      Yeah, the clutch and accelerator have no physical connection so something else is interfering.
      • E30Kills
        • Jul 2014
        • 179
        Any other ideas guys? Something binding on the accelerator is unlikely since it only happens when the clutch is pushed in. Also seems like it only happens when the car is moving, not stationary. The rpms only jump when the clutch is in.
        1991 318i - T-Boned
        1987 325is - Sold
        • ELVA164
          • 4861
          My best advice would be to get your head down there, press the clutch with your hand, and look around.
          • DREWHALL
            • Feb 2006
            • 1207
            Like someone else said the clutch system has no affect on the rpm. Something has got to be pushing the throttle when you push the clutch down.
            • ELVA164
              • 4861
              One thing that just occurred to me: Do you have floormats? The driver's floormat could have slid forward, pushing slightly on the accelerator. You may not notice it as much when you're driving, but when you disengage the clutch that may be raising the rpm.
              • DREWHALL
                • Feb 2006
                • 1207
                Exactly! Pretty sure it has happened to me.
                • Navarone
                  • Jun 2014
                  • 935
                  It's BMW's downshift revmatch feature.
                  • ELVA164
                    • 4861
                    I thought that only came on the euro M325i
                    • E30Kills
                      • Jul 2014
                      • 179
                      figured it out guys! My throttle cable was very rusted and was sticking so I have a new one coming in the mail.
                      1991 318i - T-Boned
                      1987 325is - Sold
