Intermittent brake fluid light on cluster
  • rich4rdee
    • 595
    Often when I'm braking the brake fluid lights flickers for a bit when I'm taking corners. I checked the level and it's in good shape, so I'm thinking it might be a faulty sensor? Is the body roll causing the fluid to swish around and think it's running dry? This only happens when i'm going around corners.
    Thanks for any tips!
    EDIT- Topping off the brake fluid was the fix. I simply filled it up near the top and my issue went away.
  • dnguyen1963
    • Nov 2011
    • 2651
    If the fluid is at the max fill line then it should not trigger the sensor even if you take a hard corner.
    • ST1G
      • Oct 2012
      • 6690
      Good shape meaning....
      Mine was just a hair under full and it would do this. I added a little more and it went away.
      • stonea
        • 2892
        I had the same problem, it was about 1/2 way between min & max, once I filled it up to max the problem went away.
        My Garage
        Feedback
        Instagram: Stone.Hopkins
        • Jaxx_
          • Dec 2009
          • 1880
          shit... my light doesn't come on until it's almost below min.
          • rich4rdee
            • 595
            Thanks for all the replies guys! I've got some brake fluid at home I'm gonna try out soon and I"ll let you know the results.
            • reelizmpro
              • 9558
              If you verified your level is at the max and you aren't losing fluid, then look into getting a new reservoir cap.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • rich4rdee
                • 595
                This was the fix! Thanks a lot guys.
