Ac compressor issue
  • DoneRightBimmer
    • May 2012
    • 158
    Ac compressor issue
    My Ac compressor stopped working today and i have tracked it down to a damaged wire off the right side of the Compressor I believe is it the temp sensor see item 5 in the diagram.
    http://www.realoem.com/bmw/enUS/show...diagId=64_1721
    If i press on the wires the Compressor kicks on.
    My question is can i remove this sensor without draining the refrigerant or do i have to drain it in order to replace it?
  • uturn
    • Dec 2010
    • 1008
    The sensor on the side of the compressor can be removed. It is only mounted to the housing. The sensor on the pre-1989 receiver-dryer are the ones that will open the system.
    • DoneRightBimmer
      • May 2012
      • 158
      Thank You for the help.
