Has anyone removed aux fan without moving rad/condensor?
  • Titans86
    • Dec 2012
    • 7
    I've a new aux fan on the way and am trying to prepare for the RnR but haven't found a clear answer on whether I can remove it without pulling the rad like the Bentley manual suggests.
    Looks like I might be able to remove it from the bottom if I displace the (what I think is) an oil cooler.
    Also, I've confirmed that the the fan receives 12volts before and after the resistor. Fan blades wont spin freely when forced by hand.
    I'm hoping I can, I hate replacing coolant.
    UPDATE
    Oh man what a disaster it was. On my vehicle there are three brackets holding the fan which are roughly 120deg apart, this made any kind of drop through the bottom impossible without bending a bracket backwards out of the way. I was lucky that I didn't break a bracket while bending it because they are laser welded to the body/condenser. I decided to bend the bottom left most bracket backwards.
    I was also unable to bring the electric fan in front of the brackets for the center post of the fan is literally 5mm from the steel support located behind the bumper (plastic bumper on my '89).
    My warning to anyone who wants a clean remove and replace, go through the hood and pull out the radiator.
  • Tim-sutherland
    • Dec 2014
    • 115
    I'm guessing you have an m20 since there's tons of room on an m42.
    I pulled the fan and condenser on my 325i with a lot of wiggling to get it over the oil cooler without removing anything else. If you just remove the fan itself it should be easy.
    Tim
    • cabriodster87
      • Jan 2011
      • 1042
      I've done it, just let the cooler hang down out of the way.
      Reich und Roll!
      • nrubenstein
        • 3148
        Or just delete the cooler while you are at it since it doesn't really do anything other than make it a lot harder to change the oil.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • jeffnhiscars
          • Jun 2011
          • 6011
          My understanding was that circulation to the cooler is controlled by a tstat so not seeing what it has to do with an oil change
          Alice the Time Capsule
          • Titans86
            • Dec 2012
            • 7
            Tim
            Oh man what a disaster it was. On my vehicle there are three brackets roughly 120deg apart which made any kind of drop through the bottom impossible without bending a bracket backwards out of the way. I was lucky that I didn't break a bracket while bending it because they are laser welded to the body/condenser.
            • McGyver
              • 4636
              or do it the correct way and remove your front bumper and valence...
              • Tim-sutherland
                • Dec 2014
                • 115
                Oh yeah, I guess I didn't think I needed to mention I took off the valance and bumper, they're easy and the fan is right there.
                Tim
