3rd brake light bulb removal help
  • sexyE30ness
    • Jan 2014
    • 50
    Hi all. I've been doing a ton of searching on how to replace this bulb. Now, I've gotten the cover on it off but I cant seem to get the bulb out. I pulled the connector and the pin out on the bottom of the bulb but i cant get the pin out from the left side... Am I even supposed to remove it? Am I missing something here?
    Thank you for any help and I hope I posted this in the right place!
  • TimeMachinE30
    • Jun 2014
    • 3749
    Sedan/coupe or vert?
    ACS S3 Build / Dinan 5 E34
    • sexyE30ness
      • Jan 2014
      • 50
      Its a coupe.. I didn't know there was a difference?
      Sent from my LGLS990 using Tapatalk
      • R1dd1ck913
        • Jul 2014
        • 382
        You change the bulb from the trunk not inside the car. And if you had a vert the 3rd brake light is on the trunk lid not inside the car.
        Current
        99 328i (Sold)
        91 318is M50B25TU
        89 325ix (Parted out)
        87 325is (Parted out)
        95 525i (Parted Motor for 91 318is)
        • TobyB
          • 5296
          Yup- there's a hole in the trunk directly under the bulb...
          t
          • sexyE30ness
            • Jan 2014
            • 50
            Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
            There's no access from inside the trunk. I said I had already gotten to the bulb.. I just can't get it out.
            • TimeMachinE30
              • Jun 2014
              • 3749
              Looks like your going around your elbow to get to your asshole.
              And certainly a big difference between vertical and non vertical which is why I asked. The difference, while obvious, was previously answered.
              In that photo of yours, it looks like you are pulling out the bulb from the base?? The bulb is between the red lens and that black curved piece. Trying to pull the bulb through the hole where the base mount?
              • sexyE30ness
                • Jan 2014
                • 50
                The pic of from the back seat. I see the bulb but don't know how to pull it out. I don't understand what you are asking?
                • TobyB
                  • 5296
                  That's an early car?
                  I have absolutely no memory of the 3rd brake light looking anything like that...
                  it looks like you have to remove the whole housing then?
                  t
                  • robwill116
                    • Aug 2015
                    • 5
                    Then looks like theres a clip on either end, should unclip the full housing
                    • sexyE30ness
                      • Jan 2014
                      • 50
                      Figured it out. The whole thing slides off backwards from the base. Then there's a tab on each side and the bottom you have to press. Then it was just a matter of sliding the inside part out of the housing. The bulb is removed from the inside.
                      Thanks for all the help!
                      • TobyB
                        • 5296
                        Crazy. What year is your car?
                        t
                        • sexyE30ness
                          • Jan 2014
                          • 50
                          It's an 88 seta
