Remove brake pad warnng bulb without remove cluster
  • ecsk
    • Nov 2011
    • 106
    Has anyone done that ? I'm exhausted to try to fix the f'king brake pad warning light. I now just want to pull the bulb, I read somewhere that it can be done without remove the cluster, has anyone done that ?
  • dnguyen1963
    • Nov 2011
    • 2651
    The bulb is inside the cluster. I just don't see how you can do it. It takes only a few minutes to remove the cluster.
    • Ether-D
      • Sep 2011
      • 2838
      You should be able to fix it with a wear sensor. They're cheap.
      Originally posted by Andy.B
      I was born on 3/25…
      • g.ruff561
        • 1267
        It would be better to locate the brake pad sensors and crimp or tape the wires together. Remove the driver side front wheel and the passenger side rear wheel. Locate the 2 wires that attach to the brake pads IF they had sensors. Take these 2 wires and twist, crimp or solder them together. This will create a closed circuit and the light will go off. Shrink wrap or tape them together for extra bond and shield against moisture. Take zip ties and tie them to the strut housing. Done.
        Just so you know. The wear sensors are to alert you to pad wearing below safe braking. If you elect to do the above, you must do a vizual insection of your brake pads periodically to judge wear and replacement.
        Real talk, you should vizually inspect your brake pads for wear every few months anyway. Light or no light. Automatics wear pads out faster because you use your brakes more with auto then you do with manual.
        Good luck................................ G.
        • ecsk
          • Nov 2011
          • 106
          Tried all these, new sensor, loop the wire. Brake pad warning light still on, base on this http://www.e30tech.com/forum/showthr...t=54224&page=2, I think my cluster has fault.
          • papatonymk_e30
            • Apr 2015
            • 72
            correct me if I'm wrong, but im pretty sure that closing the circuit using the method that g.ruff described would illuminate the brake wear indicator bulb. its when the circuit is open that the light is off.
            i pulled my cluster out a few weeks ago to fix a bad ground on my fuel gauge. aside from removing the steering wheel, which mightve been unnecessary, it was a simple and straightforward job
            Sent from my SM-G920P using Tapatalk
            1990 BMW 325i Cabrio
            1994 Toyota Pickup
            2006 Mitsubishi Eclipse (Lady's Headache)
            Instagram: @papatonymk_e30
            • R1dd1ck913
              • Jul 2014
              • 382
              When the sensor is new it completes the circuit and makes the light go off. When the sensor is worn down it breaks the circuit and makes the light come one. So by twisting the wires together the light wouod go off.
              Current
              99 328i (Sold)
              91 318is M50B25TU
              89 325ix (Parted out)
              87 325is (Parted out)
              95 525i (Parted Motor for 91 318is)
              • ecsk
                • Nov 2011
                • 106
                It's opposite of what you think :)
                The bulb can be accessed from outside the cluster, I removed the kick panel and checked, if I have very small hand and finger, it can be removed without remove the cluster.
                • papatonymk_e30
                  • Apr 2015
                  • 72
                  ecsk, thanks for clearing that up. i suppose i should probably figure out why my indicator stays on even though the break wear sensor circuits are all closed
                  1994 Toyota Pickup
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5270
                    It could be possible to pull the bulb with the cluster in. When I pulled my cluster to replace the lights, I quickly found out how annoying the green light for the fogs was and pulled the bulb in situ.
                    Originally posted by priapism
                    Originally posted by shameson
                    • ericneet
                      • Jan 2015
                      • 66
                      What? The green light is amazing.
