Broken recirculation door pull fitting
  • The Dark Side of Will
    • Jun 2010
    • 2796
    When I was recently getting my A/C running again, I found this:
    The pull/push rod from the recir door motor broke off its attachment to the recirc door. This means that my right recirc door is stuck open (closed? I don't know).
    How do I fix this, and is the part available?
    Can I pull the blower motor cover and get to it from the engine bay side?
    Do I have to pull the entire dash to be able to glue it or swap out the part?
    I can't see where it used to attach.
  • jeffnhiscars
    • Jun 2011
    • 6011
    You can get to the flaps by removing t he blower. The problem is that the white plastic clips that hold the flaps in place are very brittle and I don't know if you can buy them. Look for pics of an hvac unit to see how it all fits together.
    Alice the Time Capsule
    • vpilarrt
      • Jun 2006
      • 2096
      I have a complete HVAC unit I removed from my track car. When you find out what parts you need let me know. I'm sure we can work out a deal.
        • 34844
        I glued mine back together. seems to be working fine. it looked like way too much of a pain to remove & replace. Use a quality epoxy meant for plastics and I think it should hold up for a while.
          • Jun 2010
          • 2796
          I can't see where the part goes back on... much less get my hands to it. I'll pop the blower motor cover off and see what I can see on that side this weekend.
            • Jun 2010
            • 2796
            I'm in NoVA... wouldn't be hard to come by the C-Ville area and take a look at it. I have no idea how things on top of the unit look. If I can't fix or don't trust the fix on the door, I may snag some or all of it from you.
            • vpilarrt
              • Jun 2006
              • 2096
              My son goes to GMU and lives near there. He'll be here this weekend, I can have him bring the HVAC back with him if you want.
                • Jun 2010
                • 2796
                Cool. We can work something out for next week.
                How much? PM me if you'd rather.
                • vpilarrt
                  • Jun 2006
                  • 2096
                  Did you want to buy the whole unit or just whatever parts you need?
                    • Jun 2010
                    • 2796
                    I was thinking of the whole thing.
                    • vpilarrt
                      • Jun 2006
                      • 2096
                      It's complete less the heater core, AC evaporator, blower fan, blower resistor pack and #7 (passenger side) here: http://bmwfans.info/parts-catalog/E3...of_instrument/
                        • Jun 2010
                        • 2796
                        Wow! Sorry I didn't reply sooner. I didn't get a reply notification.
                        I glued the recirc door back together with epoxy, but I'll be in touch if it breaks again.
                        Pics:
                        First attempt at gluing. I wetted the broken surfaces with 5 min epoxy and kept the parts squeezed fairly hard while it set. However, the glue did not completely fill the cracks and I did not have fillet or overlap.
                        Back side after first gluing:
                        Second application, full filleting at the joints and overlap on the crack up the spine.
                        How the pushrod is disengaged
                        Push rod end fitting manufacturer
                        Doors open
                        Doors Closed
                        As I was reassembling everything, I discovered that the plastic molded around the brass inserts in the door slider structural piece that screws to the back of the face plate had cracked around the inserts... so I tried more epoxy
                        The two in this photo had actually pulled out. I didn't think to slather epoxy all over them before I pushed them back in though
                        • Poorboyz
                          • May 2012
                          • 2117
                          I'm sort of in the same boat except I removed my whole HVAC box and I'm rebuilding it completely.
                          Rebuilding since 07/06/2016
                          Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                          Poorboyz Feedback Thread
                            • Jun 2010
                            • 2796
                            I'd *like* to... it's really dirty inside. Should there be any kind of air filter on the cowl inlets?
                            Also, the foam seals on the recirc doors had completely disintegrated and the evaporator is at least 25% clogged.
                            Now that I've had it apart far enough to know all that, I'll probably pull it all the way out to rehab it when I'm doing the engine swap.
                              • 34844
                              E30s didn't come with a filter like newer BMWs. There was a version that had it, but it was only non-AC cars IIRC. and you'd have to buy a whole new HVAC unit to use it.
