Does non-airbag steering wheel HAVE to be straight before removing it?
  • e30m50swapsanjose
    • Sep 2015
    • 18
    x
    You can, but it is going to be difficult to center the new wheel when you install it.
    • TobyB
      • 5280
      For a NON airbag wheel?
      Just lock the column, mark where the wheel aligns, remove the wheel, walk away.
      I'd say you were being silly, but I bought a pickup once where that was the only
      way to immobilize it. And anyone with a pair of vice grips could have stolen it...
      Unless I'm missing something on the non- airbag wheel...
      t
      • McGyver
        • 4637
        If you don't have an airbag,
        -lock the wheel
        -use breaker bar to loosen nut
        -unlock wheel
        -finish removing nut
        -pull wheel off
        for an airbag wheel
        -un-plug battery
        -unplug the airbag connector under the dash
        -wait, or don't, i'm not you mom
        -actually, get mom to do it. that bag is gonna blow
        -Mom's too busy, so use torx bits to carefully remove the airbag (dont put your face in front of it)
        -unplug airbag and either discard or discharge and discard
        -remove steering wheel as described for non-airbag car
        Re-installation of non-airbag wheel:
        -slap it on and go to a straight street without traffic
        -remove nut and slide wheel on
        -drive a bit and turn the wheel until the car is going straight
        -remove wheel, orient it so it's straight, slide wheel back on
        -tighten nut
        I wouldn't keep a 20+ year old bomb in front of my face. It has just as much change of actually working in a crash as it does of going off when you are driving and causing you to crash.
