Do alot of e30s smoke?
  • conceps
    • Jun 2006
    • 11
    So i am looking at this 87 325is to buy and it is pretty mint and runs pretty good. But, it smokes a bit. The owner says it has always smoked a bit and i asked my friend and he said alot of the older cars smoke and its not a big problem. Any imput on this? Thanks.
  • SpecM
    • Oct 2005
    • 4531
    -how many miles on car? Is the smoke blue-ish or black?
    1989 cirrisblau-metallic 325i
    • sticksdaman
      • Apr 2005
      • 2987
      where is the smoke coming from whats the condition of the car is it a five speed?
      Originally posted by ebelements
      Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
      • browntown
        • Jun 2004
        • 3524
        depends on color, white smoke is coolant (probably head gasket)
        • conceps
          • Jun 2006
          • 11
          Sorry i left out some details. It has 233,xxx miles and it is a five speed. The smoke seemed more white maybe blueish. I didnt pay too much attention to the smoke. i should have.. Thanks for the replies!
          • conceps
            • Jun 2006
            • 11
            by the way, i might go check it out agian today. Anything i should look out for? Thanks agian!
            • Brew
              • 3060
              Blue-ish smoke is oil. Probably bad rings or valve seals. Do a leak down test to narrow it down.
              '91 318is
              • yozsi
                • Feb 2006
                • 337
                a leak down test wont determine if the oil control rings are shot.
                Unlimited Slip Diff's FTW!
                1972 240z Drift,Scca BSP, Scca ITS Car.
                • chuckybob
                  • Aug 2004
                  • 952
                  if the smoke stops after a while, its just water vapour in the exhaust
                  : : 1984 318i : : PNW E30 Crew : : Sold!!
                  Now becoming the R3vlimited Pro3 car
                  http://www.r3vlimited.com/board/showthread.php?t=93780
                  • PУCCKAЯ_e30ka
                    • Jan 2006
                    • 1226
                    test drive it.. then don't turn off the engine and look if it's still smoking if/what color... blue - oil cause: lots of miles.... any engine would smoke if not rebuild... other kind of smoke is coolant in the cylinders - bad head gasket/cracked head.
                    • conceps
                      • Jun 2006
                      • 11
                      Thanks for all the replies. definatly helpful. i think im gonna go check it out agian wendsday.
                      • conceps
                        • Jun 2006
                        • 11
                        Here are pictures of the car. i still havent gotten a chance to get over and check it out agian but he said he would take 1500. Originally wanted 3000. Would you buy it? Details are above.
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          the interior looks decent enough form waht i can see are those leather seats? i like the front lip too..
                          make sure u ask/find out when the timing belt was replaced also you could open the oil filler cap an look at the heads of the head bolts if theyre hex head not torx then theyre the old style and could break on u other then that look for rust on the under side of the car and the condition of the rubber hoses and what not under the hood other than the rust these are all things u wmight wanna fix if they are in bad shape but wouldnt be a reason to not buy the car
                          1500 is a pretty good deal if u ask me. i just paid $1400Can for an 84 325e in good shape with 288000 kms on it which i thought was a pretty good price
                          '89 Alpine S52 with goodies
                          • delatlanta1281
                            Dart Master
                            • Mar 2006
                            • 10317
                            that's alot of miles.... be ready to drop atleast a grand if there are suspension problems. When was the timing done? How bout the clutch?
                            Yours truly,
                            Rich
                            you kids get off my lawn.....
                            • chuckybob
                              • Aug 2004
                              • 952
                              id buy it, but im an utter whore for tan interiors
