Thermostat housing differences...?
    • 37833
    Is there any difference between the 87 M20B25 thermostat housing and the 88+ M20B25 thermostat housings?
    Danke.
    Grover Beach, California
    BimmerHeads.com
  • BCMike
    • Oct 2005
    • 117
    Reading these pages from the ETK, it appears that depends on the '87 build date. The later model t-stat housing started in 9/87: They sure do look the same though...
    9/87 on http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
    up to 9/87 http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
    Danke.
    Let's go exploring!
    • AdamF 88iS
      • 2051
      Some have 4 ports for sensors, some only 2.
      Some have a straight fitting for the hose that returns from the throttle body, some have a 90* fitting there.
      Adam Fogg- '88 M3
      Common sense- It's the new 'gifted'
      • eco325iX
        • Apr 2006
        • 113
        While doing some maintenance I noticed some corrosion/pitting on my thermostat housing. I was checking prices at some vendors and noticed that ones sold now whether genuine or aftermarket all have 4 threaded ports for sensors, my current thermostat housing with an "88" stamp on it (probably original to the vehicle) only has 2 threaded ports for sensors (like the one pictured in the Bentley repair manual). What are the two extra ports for and can I replace my 2 port model with a 4 port model?
        • uturn
          • Dec 2010
          • 1005
          You'll need to buy the additional plugs and crush washers to blank off the ports you're not using. Make sure you get the right size.
          • eco325iX
            • Apr 2006
            • 113
            uturn, thanks for the response. Do you happen to know if the two additional ports in the thermostat housing are the same thread pitch as the ports for the blue and brown coolant temp sensors? I want to make sure before purchasing everything.
            • jeffnhiscars
              • Jun 2011
              • 6011
              The 2 extra ports are for an eta. Threads should all be the same so just use the ones placed where your current sensors go and plug the other 2
              Alice the Time Capsule
