PSA: Spray grease is not always the answer
  • validius
    • Mar 2015
    • 161
    Broke my hood release yesterday. The culprit ended up being the hood latch which had been sprayed so much with grease that the attracted dirt had caused the sear to almost completely seize.
    1987 325i Convertible
    2015 Fiesta SFE: 1.0L of 'Woah, is that torque under 2k?'
  • razo-s.supra
    • Dec 2009
    • 124
    Nasty, wonder if dry carbon lube would be a better alternative?
    • rcsoundn1
      • Nov 2012
      • 3361
      I clean these from time to time then re-grease them to try and avoid this.
      • TobyB
        • 5238
        yeah, funny how sometimes grease isn't the right answer.
        I like chainsaw bar oil for things like that now. But it also
        attracts dust and gunge...
        t
        • and_e30
          • Oct 2014
          • 94
          Yep, spray grease really isn't of much use. I use contact grease on most applications instead.
          1991 E30 318is - Project car
          1995 E36 M3 - Impulse buy
          1998 E36 M3 - Weekend car
          2002 E46 325i - Daily
          1991 E30 325i - Sold
          2003 E39 540i Msport - Sold
          • rcsoundn1
            • Nov 2012
            • 3361
            I have used 10w-30 in a pinch on these before.
            • mjimport
              • Jan 2010
              • 418
              I'm having this problem now, I feel like I'm almost snapping the handle off just to release the hood.
              I noticed mine is quite rusty. Is there a way to refurbish and get more years out of it, or do I need to just buy new?
              Edit: yes I see they are only $30 from ecs, but I have spent hundreds $ in the last few weeks and am trying to slow the spending.
              • TimeMachinE30
                • Jun 2014
                • 3749
                Clean it. Just adding grease is not the answer. Clean and relube.
                ACS S3 Build / Dinan 5 E34
                • LounsRacingInc
                  • Mar 2015
                  • 61
                  My 87 4 door has the same issue, the hood latch barely works and usually needs two people too open because the grime build up from using spray grease got so bad that someone (before I owned it) forced the hood open and broke the release springs :/
                  I put a new set on and used a very light light coating of red chassis grease that seems to work. But time will tell how it holds up to dust and grime
                  1987 LuxorBeige 325 4 door (daily)
                  1988 Zinnoberrot 325 4 door
                  1984 and 1986(7)? Parts cars
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    It is an area subject to a lot of contamination. I keep up in this as a broken cable and hood stuck closed sucks. The E38 and E30.
                    • TobyB
                      • 5238
                      ...still swearin' by that bar oil, myself....
                      t
                      • validius
                        • Mar 2015
                        • 161
                        I just got the car out for the summer and replaced the mechanism.
                        I'm going to use some 'dry' garage door spray lubricant. If it causes a problem i'l try and remember to dig up this thread in a few years.
                        • Kershaw
                          • 11822
                          I use penetrating oil, instead of white lithium grease. It keeps it lubricated enough and doesn't gum up.
                          AWD > RWD
