Combining driveshafts - yay or nay
  • jrobie79
    • Mar 2006
    • 2526
    How bad would it be to take the front half of an m42 driveshaft and match it to the rear half of another m42 driveshaft?
    I have two, and obviously one has a good rear u-joint, but the front is notchy as hell, on the other it's opposite. Assuming I align the "new" one correctly would this be that bad?
    (Not looking to shell out the dough for a reman - that'll be fine when it's parked for winter)
    1991 318i ---- 308K - retired
  • Farwest92
    • Jul 2011
    • 192
    I tried that on my 87. No problems until I hit fresh pavement while doing 75. I noticed a slight vibration on the floor. I switched back to the original half with older u-joints and now it's smooth.
    Give it try, it might work for you.
    • jeffnhiscars
      • Jun 2011
      • 6011
      Drive shafts are balanced as a unit so the odds of 2 unrelated halves spinning smoothly are somewhere between slim and none
      Alice the Time Capsule
      • ahlem
        • 369
        Check to see if you have a local place that balances drive shafts?
        • TobyB
          • 5264
          It'll work just fine. It WILL vibrate a bit more- maybe at 45, maybe at 95.
          And you can always try reclocking it 180 to see if you get lucky.
          Locally, it's like $35 to have one balanced.
          hth
          t
          • Bmwdayz
            • Apr 2011
            • 610
            It won't be fine. You will be able to drive the car but the vibration from the unbalanced driveshaft will make you crazy. It need's to be balanced
            • whodwho
              • Jun 2008
              • 1547
              There is more of an issue when the joints are out of phase
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • TobyB
                • 5264
                Having done it a few times, chances are pretty good that if you PHASE it correctly,
                it'll work. Pretty well... up to a certain speed.
                Shit, I cut 4" out of one once, didn't balance it, and it didn't vibrate under 100...
                So try it- worst case is you'll need to have it rebalanced. Which isn't much, compared to
                the cost of a new one.
                t
