Airbag Car 5 speed swap.. brake light switch?
  • Julien
    • 7471
    I searched-ish.. Now that i've swapped out clutch and brake pedals from an 88 325i/vert the brake light switch won't make contact with the brake pedal. I've tried to adjust it to no avail. How do I make it blend?
    Thanks
    Build Threads:
  • Julien
    • 7471
    Solution is:
    Remove brake pedal and adjust clevis on brake booster (counter clockwise) while counter holding booster shaft until pedal hits brake switch (reinstall after 2-3 turns to test)
    Build Threads:
      • 34844
      I taped a washer to the back of the pedal, lol.
      • FredK
        • 14763
        Search noob
        • FredK
          • 14763
          But nah, it's exactly as you described. Undo jam nut and move clevis out until the switch works.
            • 34844
            Doesnt that raise the brake engagement point?
            • bmwstudent
              • Sep 2011
              • 1364
              I seem to remember a different bracket and brake light switch from my brother swap. Its a 90 going from auto to manual. Also saved the harness plug from the donor car because the switch plug was different.
