Can't remove trans fill bolt
  • 89325iturbo
    • Mar 2004
    • 723
    Can't remove the 5 speed trans fill bolt. I had the trans out, and should of tried to loosen the internal hex nut. But figured I'd just wait to I got it back in the car.
    I know I'm down fluid because when I was cleaning it, and tipping it around I had a decent amount come out the vent/ breather.
    I don't want to drive it, not knowing how much is in there.
    I've sprayed it, put some heat to it aswell.
    Thought about putting a pipe wrench on it?
  • Kershaw
    • 11822
    Have you put a breaker bar on it? If that doesn't work, have you tried a 6 foot pole slipped onto the breaker bar?
    AWD > RWD
    • Coupelx
      • Oct 2013
      • 169
      you plan on him tipping the car on its side first?
      • blwn24v
        • Nov 2015
        • 11
        6 foot pole is a bit extreme
        • Kershaw
          • 11822
          ... the point is he needs a bit more leverage.
          AWD > RWD
          • 89325iturbo
            • Mar 2004
            • 723
            Yeah I've had a little breaker bar (about a foot long) on a 1/2 inch ratchet which is already longer. I'm using the doubled up nuts on a bolt method.
            But yeah I can't get good leverage being only up on jack stands.
            • Kershaw
              • 11822
              A foot long breaker bar is not much of a breaker bar. 18-24" is usually what you need. Sounds like you need a new breaker bar. Remember, cheaper ones may flex more. Kind of useless in tight spaces.
              You might need to ask a friend who lifts.
              Repeated daily soakings of PB Blaster for a week are usually pretty helpful.
              AWD > RWD
              • TimeMachinE30
                • Jun 2014
                • 3749
                Do soak the fastener with PB routinely for many days.
                Or use this as perfect excuse for a tool....say, go out and get you a 1/2" Milwaukee Fuel impact.
                ACS S3 Build / Dinan 5 E34
                • 89325iturbo
                  • Mar 2004
                  • 723
                  I meant an extra foot extension on the foot long ratchet. (My breaker bar is just a piece of pipe) So close to two feet together.
                  I got the plug out though. Jacked the car up higher using some 2x4's on top the jacks. Allowed me a better angle to get some leverage on it.
                  Appreciate the ideas.
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    When disconnecting the drive shafts at the diff, I muscled it off by using my legs... not arms.
                    • 89325iturbo
                      • Mar 2004
                      • 723
                      ^^^ been there done that on various cars/bolts. As long as I feel like I got a good lock on the nut or bolt so I don't round it off with pushing with a leg.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        A 50/50 mixture of acetone and ATF will be better than PB blaster. Popular mechanics did a test a few years back and it exceeded every other off the shelf penetrating oil they tested.
                        Get more leverage. I have this guy and it works very well:
                        http://www.harborfreight.com/12-in-d...bar-60819.html
                        Also, pick this up while you are at it so you have a proper socket:
                        http://www.harborfreight.com/9-piece...set-67880.html
                        • Kershaw
                          • 11822
                          My friend has that HF one. I've seen it flex a lot. Makes it hard to break a bolt in a tight space. I prefer this one, although it is a bit shorter http://www.amazon.com/Craftsman-9-44.../dp/B00065T0MS
                          AWD > RWD
                          • McGyver
                            • 4637
                            Unless you want to strip the fill plug, this is what you need. You'll be able to use the most force without damaging something. I actually use one where the hex part can slide out of the socket. I slide it through a ratcheting wrench and into the cap. It makes it super easy and safe.
                            • b*saint
                              • 3794
                              Impact gun. Dont be a chicken.
                              Ma che cazzo state dicendo? :|
