Hi all,
Not sure where to post this question.
I have been working on my 84' 325E and I came across a lil problem. Had the car in a shop for a while and decided to bring home to finally fix. Car would start up fine for months. I decided to replace some parts in the engine.
Went and replace the following:
Fuel pump
Fuel filter
Fuel lines
Fuel pressure regulator
Coolant hoses
Water pump
Thermostat and housing
Belts
Timing belt and tensioner
Spark plugs
Air filter
Drained and refilled coolant
After all this work, I went to start it up and the OBC is not powering up. Therefore I cant enter the starting code.
The tachometer and odometer section is working fine. I replaced the light strip and rear light for the OBC and still nothing. The fuses all seem to be good as well. Any thoughts or suggestions to what causes this or did it crap out on me?
I accidentally posted same message in Project forum but im gonna post pics there later as I progress.
Thanks
Sent from my SAMSUNG-SM-G920A using Tapatalk
Fuel pump
Fuel filter
Fuel lines
Coolant hoses
Water pump
Belts
Spark plugs
Air filter
Thanks
