Wiper delay issue
  • Daeldalus
    • Nov 2012
    • 304
    Wiper delay issue
    I searched around already but didn't see anything exactly about this.
    My wipers will sometimes switch to full speed while on the intermittent
    speed setting. All other speed settings and off works fine. sometimes it
    will be working fine and then i hit a bump and it will go on full speed
    but will go back to normal after i turn wipers off and then back to low
    setting.
    so, switch? ground for the switch? motor? corroded fuse? failing relay?
    any insight will be appreciated.
  • audiquattrot
    • May 2008
    • 3836
    remove steering wheel, and tighten the ground screw for the turn signal stalk (Philips head). this fixed my intermittent wiper issue. Sounds like the same if it happens when you hit a bump.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • Daeldalus
      • Nov 2012
      • 304
      just did that.
      both grounding points behind the steering wheel were
      a good bit loose I guess only time will tell whether or
      not that was the problem.
      thanks
      • craiglepaige
        • Nov 2015
        • 22
        I kind of have the same issue, so I will go ahead and check those screws.
        Now since I haven't done it, I'm not sure if this will work, but why not add a small safety/spring washer to the screw to prevent it from coming lose in the future?
        • Das Delfin
          • Sep 2014
          • 2293
          ^ I actually just did this with my gas/temp gauges. I dunno why a lock washer wasn't used from the factory. Also it helps to sand as much of the electrical contacts as you can.. bmw stuff gets dirty!
          • digger
            • Nov 2005
            • 6198
            wiper relay fault can cause strange things like this.
