Late e30 abs not working.
  • danielpak_ek9
    • Dec 2014
    • 375
    Hi my abs just died after a few jump starts and according to my research the early models have a relay that needs to be resouldered for it to work. But the late model do not and I'm wondering if there is a protecter relay on the late model e30 as the early model? If so, where is it?
  • Fixedwheelnut
    • Dec 2015
    • 4
    It's a silver relay bolted just above the Glovebox catch, well on a right hand drive atleast :)
    • Hellabad
      • 807
      There can actually be a fuse on top of the relay, either the fuse or soldered connections inside acting as a fuse need to be looked at. Amazingly simple and obvious once you see it with your own eyes.
      Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
      Ground Control Gallery
      The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
      • danielpak_ek9
        • Dec 2014
        • 375
        The thing is , is I'm trying to find the relay. On the early models it is on top of the abs computer where the dash is. But on the late models there isn't one. Or at least mine. Are the main relays right on the abs pump? There are 2 of them there. I opened up both if them and nothing. Looks like a regular relay with no protective cuircuit
          • 34839
          On late cars the relay is on the pump.
          • danielpak_ek9
            • Dec 2014
            • 375
            is there anyway to fix them or i will need new relays?
            • itsonlygeorge
              • Feb 2014
              • 852
              There is a metal cased tall ABS relay under the drivers kick panel in my 87, right under the steering column. It is fused internally and can be soldered by removing the case. You can test any relay with a 9v and some alligator clips and a multimeter. I had the same issue when I got my car. I pulled a relay from a yard and it cost me $5.
              1987 325e Lachssilber w/ MarkD chip and late bumpers, Zender EVO spoiler, s3.25 LSD
              I don't think there's really strong evidence that ZDDP harms cats.
              • danielpak_ek9
                • Dec 2014
                • 375
                Yea I have a 86 parts car as well and I did find one in that location but the late models are different.
                • danielpak_ek9
                  • Dec 2014
                  • 375
                  to the top. need this figured out.
                  • TobyB
                    • 5243
                    You want the '89 version, as it covers 89-91 ABS. No, there is no fuse
                    as there is in the overvoltage relay on the early cars.
                    Time to start troubleshooting...
                    t
                    • danielpak_ek9
                      • Dec 2014
                      • 375
                      Bump
                      • danielpak_ek9
                        • Dec 2014
                        • 375
                        bump
                        • TobyB
                          • 5243
                          No, there isn't.
                          t
                          • E30 331is
                            • Sep 2011
                            • 1166
                            Was this ever solved?
                            • Seawolf
                              • Feb 2015
                              • 270
                              What TobyB said.
                              Late models (89 on) do not have the external relay under the dash.
                              The relay is integral with the ABS Hydraulic control unit, the relay does not have an internal fuse link.
                              So what are the symptoms ? Is the ABS light on or the ABS system appears to not be working ?
