Slave or Master?
  • e30AlexP
    • Dec 2015
    • 2
    Slave or Master?
    My clutch pedal had dropped to the floor no pressure in the pedal or nothing. Knowing its going to be the master cylinder or the slave cylinder, I would like to know your input. There was not one drop of fluid on the floor or on the inside of the car which has thrown me off. Clutch is a brand new Sachs. Replaced literally 2 weeks ago. Fluid level is the same level it was at before this issue has happened. Can anyone else help me with this? :(
  • glnr13
    • 1334
    slave
    • Das Delfin
      • Sep 2014
      • 2293
      well when my slave went there was a wet spot under the car
      • reelizmpro
        • 9558
        First thing I would do is get under there and visually inspect the clutch master and it's connections. The rod to the pedal sometimes breaks, sometimes the bracket breaks especially if you have a stiff clutch. Check it all out first before getting under the car and checking the slave.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • raudonis
          • Jan 2013
          • 184
          There does not have to be a fluid leak for a defective cylinder. It can be pulling air into the system without squirting fluid out! If you can't find a leak and fluid level stays the same change both slave and master and save yourself the headache.
          My transaction feedback on r3vlimited :):Clickety click
