water pump removal and install
  • Group A
    • Feb 2006
    • 201
    can someone sum up a removol and install of a water pump for a 86 325 for me? in my mind im just assuming i just have to remove the radiator, remove the fan, and then take out the water pump and put a new one in. let me know if im missing something or i got it wrong. i know the fan cluth requires a 32mm(i think) wrench to remove, will i need a specialty wrench, like a fan clutch wrench to remove it or will a regular one fit?
  • Group A
    • Feb 2006
    • 201
    u guys suck...imma go drink a fifth of rum and just start taking thiings apart. and it will be your fault a E30 is destroyed, because you wouldnt help me...:drink:
    • etxxz
      • Feb 2006
      • 2085
      haynes/bentley manual is a suggestion. haven't done the waterpump on my e30
      No more e30s for me.
      88 black BMW OBDII 332is dedicated track [sold]
      88 BMW OBDII bronzit 332is [RIP 03/08]
      91 BMW 325i [sold]
      86 Corolla 'Ae86' HB 20v trd [sold]
      http://youtube.com/watch?v=pTj7Hn9v5Rs
      • NC325iC
        • Mar 2004
        • 6565
        remove timing belt unbolt water pump, install is reverse
        • Group A
          • Feb 2006
          • 201
          timing belt? gay...i was hoping it would only be the seprnetine belt
          • 1991 318is
            • Dec 2005
            • 786
            This is a walking, talking alcoholic we have on our hands here.
            • Sean
              • 5793
              No serpentine belt in E30.
              Timing belt must be done at same time - which is why they are usually done in conjunction.
              - Sean Hayes
              • silversleeper
                • Mar 2005
                • 2032
                question that is somewhat on topic here...
                when removing the distributor rotor, the allen key size, what is it? I used on in there and the screw was in there pretty hard, and it got stripped.
                Claus Luthe is my hero.
                • s52e368
                  • 539
                  depends what year you have .
                  • Group A
                    • Feb 2006
                    • 201
                    i did the same exact thing on my accord, hahahaha. except it was a philips head screw and not allen. its still stripped and still in there :-?
                    • Group A
                      • Feb 2006
                      • 201
                      since im going to be putting in a new wtaerpump im going to go ahead and change the timing belt. can someone give me a link to a how-to write up or kind of sum it up for me?
                        • 34844
                        actually, you can do the waterpump without doing the timing belt, but it's maybe 10 minutes more work, and $35 in parts, so you may as well do both at the same time. whatever you do don't put in an old timing belt!
                        • Group A
                          • Feb 2006
                          • 201
                          can i just slip off the old timing belt and slip on a new one and just make sure the crank and cam gears dont move or do i have to put #1 cylinder in TDC and line up everything before removing and installing the new one?
                          • s52e368
                            • 539
                            this helped me with the camshaft seal ....
                            M20 timing belt
                            • adept
                              • Feb 2006
                              • 425
                              Make damn sure its on TDC when you pull off the timing belt... and when putting on the new one... make damn sure its on TDC on both the top and bottom. This mistake probably cost me around 4k :-p
