Help identify Diff
  • Th3importedguy
    • Mar 2014
    • 190
    Help identify Diff
    What diff is this and does it fit my 91 318i??
    E30 is life :finger:
  • Chuck C
    • 104
    The 7 digits are the part number for the small case diff. It should fit your car.
    • Th3importedguy
      • Mar 2014
      • 190
      From my research is that 3.91 lsd???
      • Fsnow
        • May 2015
        • 184
        Usually the little metal tag on the upper left cover bolt will have numbers stamped on it(if it starts with S it's a limited slip) , unless of course it is so rusted that it's unreadable. In that case turn the input and see how many times you have to turn it to get the outputs to make a full rotation. It is small case and will fit. There may also be an S painted on the bottom of it if its limited slip.
        1991 318is x 2 .
        • vpilarrt
          • Jun 2006
          • 2096
          A large case diff will also fit the 318i/is. The small case was used because its lighter and you don't need the larger diff since you have less torque with the 318 engine.
          • YosemiteSam
            • Apr 2011
            • 1303
            I think you mean the Medium case, I don't believe large cases fit in E30's.
            • vpilarrt
              • Jun 2006
              • 2096
              You are correct
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                What are numbers on this tag??
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • TobyB
                  • 5280
                  Yeah, ^ that.
                  t
