So....I have a serious relay question
  • joecrotch
    • Dec 2008
    • 117
    So I have discovered that almost all of my relays are bad or on the verge of going bad. If I want to replace all of my relays is there somewhere to buy them for decent price? Or am I really going to have to shell out a few hundred bucks just for relays?
    There has to be somewhere to get them cheap. Is there another model of car that uses the same relays? because as soon as you tell anyone they are for a BMW the relay automatically becomes priceless.
  • digger
    • Nov 2005
    • 6201
    I'm sure you get relays from ecs tuning, fcp euro or pelican parts etc for a reasonable price
    • joecrotch
      • Dec 2008
      • 117
      checked Pelican more or less 10 bux a pop. I will check ECS and FCP.
      • ELVA164
        • 4861
        Why are all of your relays going bad at once? That seems a bit odd.
        • Kershaw
          • 11822
          You can buy the 4 and 5 prong relays at advance auto in their electrical section.
          AWD > RWD
          • TimeMachinE30
            • Jun 2014
            • 3749
            Are you sure you do need relays? To all go bad at the same time is wild.
            Junk yard.
            Which ones do you need? I have a bag of them.
            ACS S3 Build / Dinan 5 E34
            • LounsRacingInc
              • Mar 2015
              • 61
              I think all the relays on a e30 are pretty generic four and 5 leg relays with the exception of the main relay. The main relay is a 4 leg relay that has 5 legs, two of the legs are power out, one to the DME and one to the injectors (it has two 87 legs)
              1987 LuxorBeige 325 4 door (daily)
              1988 Zinnoberrot 325 4 door
              1984 and 1986(7)? Parts cars
