Wondering if anyone else had this issue and know which part exactly fails and what to buy to fix it. Per the parts diagram there are a bunch of hoses and pipes and I'm trying to figure out which part it is. Since weather is crap haven't had a chance to pry everything open and look.
Saw this on the E30 Wiki
"The pipework for the rear wash-wipe is relatively simple. Fluid is poured into an access nozzle on the bottom left corner of the rear hatch (just above the rear lights) to fill the tank. From there, the pipework runs from the tank via the pump up the inside of the D-pillar, over and through the left tailgate hinge, around the left side of the tailgate side to the wiper motor.
It is very common for the section of pipe above the tailgate hinge to split, causing a leak into the headlining every time the rear wash-wipe system is used."
