91 'iS General Wear Parts
  • MouseRat
    • Nov 2015
    • 75
    Planning a bit of an overhaul of the underside of my 91 'is when the weather is a bit less shit. I have a little list of bits that I already want to do
    Little list..
    Poly Diff Mount (Clunk when lifting off/getting on it)
    Engine + Tranny Mounts
    Rear Shock Mounts (not noticed any noises but they're 25 years old so might as well)
    Fan Clutch
    Water Pump
    Timing Chain tensioner
    While it's not being driven in April, I want to make sure everything is solid, so are there any other general bits that I should look at replacing?
    How would I tell if subframe mounts and trailing arm bushings ect are bad?
    Thanks
  • stonea
    • 2892
    Personally I would just drop the subframe. You its not to terribly difficult (but I've always had a lift) Then you can replace the subframe bushings and trailing arm bushings. Make sure your guibo is good, and check the CV boots.
    My Garage
    Feedback
    Instagram: Stone.Hopkins
    • TobyB
      • 5238
      Lollipop mounts
      Timing chain tensioner stuff...
      struts.
      rack and inside tie rod ends...
      Really, whatever you can poke at that doesn't look right.
      t
