This is going to sounds dumb but need some help
  • dmb62
    • Oct 2015
    • 42
    I'm trying to remove one of the screws holding my elipsoids on my parts car and can't get it off I've used a Phillips head attachment to my ratchet a screw driver an impact drill and tired drilling it out but it broke the bit in side it. Unsure of what to do should I try using jb weld and putting a nut on it ? I don't want to have to cut off the piece holding the elipsoids on and don't know how else to get this screw off all input is appreciated as I need to get it off asap thanks
  • doorman
    • Mar 2015
    • 360
    Spray some PB Blaster on the screw and let it sit a bit....then spray a bit more.
    Sometimes trying to tighten the screw/fastener just a bit can break it loose.
    • dmb62
      • Oct 2015
      • 42
      There's a drill bit stuck in it now and the threads are drilled through. Il try the pb blaster and then jb weld it tighten then try and loosen
      • ELVA164
        • 4861
        Substitute aluminum cutting fluid for the PB. Sounds weird, but the stuff is magic.
        • Sputnik
          • Jan 2010
          • 808
          post pics but. if you can...(1. pry the broken but out the screw (2. soak it in some penetrative spray (3. dremel a slit on the broken piece (4. use a flat head to screw it out.
          • george graves
            • 20003
            If you own a e30, you should own a can of PB Blaster.
            You'll laugh at the design on the can, it's really old school, but it works better then anything else. If you're really poor, I hear you can write them and ask for a sample, and they will send you out a tiny little can for free.
            Originally posted by Matt-B
            • TobyB
              • 5297
              Don't suppose you can get needle nose vice grips on the head?
              t
