AC Question
  • jeffnhiscars
    • Jun 2011
    • 6011
    Originally posted by Cephas
    This is the hard part as I'm finding. Have any lines on where I can get one :)
    They are NLA. I got mine off of Amazon. In my Cabrio build thread there's PN's
    Alice the Time Capsule
    • Cephas
      • Apr 2012
      • 878
      Originally posted by Tim-sutherland
      Yes, I did the retrofit from the diy thread.
      I did have to use the manifold from the old compressor, which is the two metal inlets from the hard lines that cover the 4 holes on top from the autozone picture.
      Part numbers 1 and 2 in this diagram for my compressor.
      http://www.realoem.com/bmw/enUS/show...diagId=64_0549
      Sent from my SM-G900V using Tapatalk
      One more question. Did you have to change the pulley over from serpentine to v-belt Tim? Looks like the autozone one might be a serpentine.
      • Tim-sutherland
        • Dec 2014
        • 115
        I actually ordered the wrong one first, and had to switch out to a more expensive one they list for my car, which is part number 57352. This one is v belt and has the correct mounting on one side of the compressor.
        If you have an old compressor to look at, just look very carefully at the model number it replaces, not just the brand. If not, look carefully at the mounting points to make sure it will work. My engine is an m20, but only one of the many compressors they list for it actually mount up.
        The good thing is that it wasn't a pain to return the wrong one to the store, I just had to wait a couple more days to get the correct one.
        • Cephas
          • Apr 2012
          • 878
          Shoot. I ordered the wrong one. Just opened the box and it is indeed a serpentine. Hopefully they will honor the 20% off coupon I had since they say this cheaper one fits when it clearly does not. Looks like I probably need the same one you ended up ordering.
          • Tim-sutherland
            • Dec 2014
            • 115
            I think they pretty much always have the 20% off coupon on the website for ship to home orders.
            • Das Delfin
              • Sep 2014
              • 2293
              Hey you guys. With your new compressors. Did they come loaded with oil? Or did you have to add it?
              • spike68
                • Apr 2009
                • 1185
                They probably don't come with oil, but it's easy to check just tip it over and see if some oil comes out lol
                Sent from my SAMSUNG-SM-G925A using Tapatalk
                I don't even own this car anymore, but I'm too lazy to change the picture.
